First Reduction Gear Lubrication
JC
02-15-2004 06:08:04
I am re-assembling my "D" and just wonderd how the first reduction gears {belt pulley gear and spline shaft gear} get sufficient lubrication?
The felt in the RH main bearing will hold back most of the sloshing oil from the engine and the drain hole back into the engine compartment looks to be above the oil level in the crankcase. {The tractor is 80 kilometers away at a friend's shop so I can't look at it today}.
Comments..... ..... .
Thanks,
JC
Clooney
02-15-2004 07:04:00
 Re: First Reduction Gear Lubrication in reply to JC, 02-15-2004 06:08:04
JC, the first reduction gears & related parts under the 1st reduction cover are lubed from engine oil..
The oil gets into the reduction cover by flowing out past the R/H main bearing at the crankshaft...
Once the engine oil is in the 1st reduction cover it gets tossed around by the gears. To assure adequate continual lubrication there is a partial wall in the 1st reduction cover so a quart or two of oil remains in the bottom rear of the reduction cover & the big 1st reduction gear's bottom sits in that oil & caries it up to the clutch gear..
As you mentioned there is a oil drain back hole in the bottom of the 1st reduction area that allows excess reduction oil to return to the engine sump..
Pretty simple but quite effective....
[email protected]
JC
02-15-2004 10:32:48
 Re: Re: First Reduction Gear Lubrication in reply to Clooney , 02-15-2004 07:04:00
Thanks Clooney,
I'll take a closer look at it next time I'm at the shop. It looked like all of the oil flowed back to the main compartment thru that drain hole! Your explanation certainly makes sense.
Regards,
JC
mike
02-15-2004 17:57:40
 Re: Re: Re: First Reduction Gear Lubrication in reply to JC, 02-15-2004 10:32:48
do the 60's and 620's just run gear lube? or does it take engine oil too?
Clooney
02-15-2004 18:16:23
 Re: Re: Re: Re: First Reduction Gear Lubrication in reply to mike, 02-15-2004 17:57:40
Mike, the later Deere's like the 60 & 620 use an oil seal on the R/H main bearing to keep the engine oil out of the 1st reduction cover. Those later tractors use gear oil from the trans to lube the 1st reduction cover gears..
[email protected]
mike
02-15-2004 19:31:17
 Re: Re: Re: Re: Re: First Reduction Gear Lubricati in reply to Clooney , 02-15-2004 18:16:23
thanks again clooney
