40-41? John Deere B Starting
Jeff Bates
01-27-2005 07:08:17
I have an old B that will crank the 1st or 2nd time almost everytime, but if it dies before you get your fuel and choke adjusted you can crank for an hour and may not start it! Starts well by pulling. Has great compression, sounds good, getting plenty of clean fuel. Don't know about my spark from the X Wico, Orange/yellow spark, New plugs gapped at 35. Opening petcocks????? But like I say, when I get home today I would about bet that it will crank good the 1st time.
Thanks
Jeff
1945 A
01-28-2005 13:17:00
 Re: 40-41? John Deere B Starting in reply to Jeff Bates, 01-27-2005 07:08:17
I used to have a devil of a time starting my "A", especially after it had run for a couple of hours. I tried all the suggestions----wires, different types of plugs, checked, and rechecked gaps, points, you name it.
I finally gave up and ordered a rebuilt magneto from Belanger's (in Maine).
Best move I ever made! The old tractor starts every time, I don't foul out plugs anymore, and can even refuel, and she'll start right back up again. Bottom line is, make darn sure you get that fat blue spark that will jump at least 3/16ths of an inch, every time she fires, or your wasting your time, IMHO..... .....
Jeff Bates
01-28-2005 16:25:29
 Re: 40-41? John Deere B Starting in reply to 1945 A, 01-28-2005 13:17:00
Do you have any phone #'s where I could buy a mag? I kinda figured that was the problem!!
1945 A
01-31-2005 07:21:53
 Re: 40-41? John Deere B Starting in reply to Jeff Bates, 01-28-2005 16:25:29
Belanger"s Auto Electric
127 Cyr Rd.
Cross Lake, Maine 04779
207-834-7309
The main reason I went with these folks, is that they answered my emails. I couldn"t get a response from others (like Roberts).
Steve (owner, I think) was very helpful, and I got excellent service. Good Luck!
P.S. Before I bought the rebuilt mag, I did everything everyone suggested, carb adjustments, valve adjustments, diffferent spark plugs, different gaps, etc. Since I"ve replaced the magneto, the tractor starts very easy---like it"s supposed to.
Jeff Bates
01-31-2005 14:38:02
 Re: 40-41? John Deere B Starting in reply to 1945 A, 01-31-2005 07:21:53
Appreciate the phone # on Belanger's. I already have it on order. Steve seemed to be very helpful. Thanks Jeff
Will P
01-27-2005 14:13:07
Make sure you are using solid metal core wire. Don't use carbon core suppression wire that you use on your car. Mags don't like anything but metal core.
Will P
Dave in S MN
01-27-2005 11:33:20
Hi Jeff-
old is correct. There is supposed to be a nice blue spark there at the plug. Mine had much the same problem and I gapped the points to the manual specs and cleaned them off as well. An oxidized set of points could potentially cause the problem you"re having. But if it"s not the points, condenser, or plugs, your mag may need rebuilt.
-Dave R
ChuckW
01-27-2005 09:22:56
Just checked ebay and there is a good assortment of nice mags on for auction.
ChuckW
01-27-2005 09:20:38
One of our club members has a 38 B and we would have to pull to start. Weak Mag was the problem. As you try to start, fuel grounds out the plugs and you mag is not hot enough to fire through gas. Rebuild mag or get a rebuilt one and you'll be set. A lot of the time the magnets are real weak and you have to have someone that can restore the magnetism. Good luck.
BushogPapa
01-27-2005 07:37:15
You might try setting the plug gap down to .025 and see if it starts easier..that would suggest a weak ignition, but I think it sounds like you are chokeing it too much... Try starting it with the gas turned OFF..that might help keep you from flooding it at start-up.. Nothing make them harder to start than flooding.! Nevt time it is hard to start, change to a new set of plugs...after you turn it over a few times with the plugs out to clear the cylinders... Let us know what you find out..!!!
Ron.
Jeff Bates
01-27-2005 08:38:15
 Re: 40-41? John Deere B Starting in reply to BushogPapa, 01-27-2005 07:37:15
Appreciate the info. Where can I get a tune up kit for this mag if in fact, that I need one?
BushogPapa
01-27-2005 11:48:01
 Re: 40-41? John Deere B Starting in reply to Jeff Bates, 01-27-2005 08:38:15
About all you can do is change the points, or make sure there is no corrosion on the contacts of the points, keep the cap clean AND Moisture free....!!! I had a problem with my "B" fouling the Rt plug a few years ago--I seldom work it very hard--and I found a set of "spark Intensifiers" at a flea market...meant to be used on a V-8...the kind that plugs ( one in each plug wire location ) in the distributor cap.. They had a wire running between each intensifier--to the next.. I cut 2 off and left the two connected together..
Plugged them into my mag, and have not fouled a plug since..!! Maybe that would help you... Narrowing the plug gaps will reduce the amout of voltage needed to jump the "gap".. I had a JD 60 that would once in a while leak fuel into the cylinders when it was shut off, and/or flood at start-up...I got so I started it with the fuel still shut off and had very few problems starting it that way...and it Never spit fuel out the exhaust when it started after that..!! Your early "B" probably has the petcocks on the Side of the cylinders..if so, you can't dry out the cylinders as easily as the Later ones with the petcocks on the bottom...That makes it harder to get the cylinders dried out if it does get flooded... Hope this helps....!! Ron.
BushogPapa
01-27-2005 11:47:58
BushogPapa
01-27-2005 11:47:55
old
01-27-2005 07:23:09
Spark should be a nice blue color. You might need to clean/replace your point and condensor.
