730 D Taperloc Flywheel?
Tony-Ont
01-27-2005 06:40:34
On my 730 D it already has a taperloc flywheel and it has come loose, I don't need the flywheel it is fine, my question is can I just buy the taper spline and nut or do I need the complete flywheel?
mrob 7
02-06-2005 22:10:03
 Re: 730 D Taperloc Flywheel? in reply to Tony-Ont, 01-27-2005 06:40:34
I recently purchasd a 730 D and it came with a tapor loc flywheel in a box. It appears to be in good condition.
JDBert
01-27-2005 13:08:56
Did it actually wreck the taporloc? I put one on a 730 back in about 90 or so. That one always seemed to come lose. We used this tractor quite abit, culivated 600 acres with a 8-30 rm on the 3 point, which is a whole nother story, sprayed, mowed ect. We could never get it tight enough, we ended up building a wrench, which I still have if any one needs pics and put a long bar on it. We would tighten it use it for 1/2-1 day tighten again and so on it finally held then I sold it Verplug (spelling) in Iowa in about 93-4 ish and it was still good then. I dont remember where I got that one it was about $700 I do remember that, and it had a big square nut to tighten it.
Tony-Ont
01-27-2005 17:21:13
 Re: 730 D Taperloc Flywheel? in reply to JDBert, 01-27-2005 13:08:56
Thanks to everyone for your info, I am going to try and get the taperloc spline.
Clooney
01-27-2005 07:38:07
Tony, you ask,,
Quote:--� I don't need the flywheel it is fine, my question is can I just buy the taper spline and nut or do I need the complete flywheel?�
--You should be able to buy just the center taper hub,, problem is there are a few places making those taper-loc flywheels so you will probably need to find the place that built it to begin with.. Those center hubs MIGHT all be the same but I do a lot of machine work so have my doubts they will all interchange..
Clooney
ChuckW
01-27-2005 07:32:24
I would suggest you check with the flywheel supplier. I haven't ever seen the wedge sold as a seperate item. I suppose one of these could be machined but at what cost. The wedge collar is the heart of the mechanism.
