60 Clutch pulley problem
JDMAN60
01-27-2005 03:57:46
I have been restoring my "60" and the sliding collar in the clutch pulley has some wear in the small hole where the pin that holds it from turning goes through and some wear on the pin itself, but I don"t know how to remove the pin. Is it a threaded stud or does it just press in? I thought I would drill the collar out and make a new pin if that is possible.
Clooney
01-27-2005 06:10:28
 Re: 60 Clutch pulley problem in reply to JDMAN60, 01-27-2005 03:57:46
JDMAN60, that pin is just pressed in. Usually a set of vise grips will work or weld a nut on & use a slide hammer.. A lot are open on the reverse side to allow a drift to drive it out from the back..
When replacing that pin DON�T just drill the hole oversized in the sleeve as those pin holes usually only wear in one direction.. If you just drill oversized that will not allow the operating sleeve to be centered for correct over-center action on the toggles.. I usually use a small die-grinder or dermal bit & grind the hole to be somewhat round & back on original center then drill to be round with a drill bit.
On the pin,, I personally don�t enlarge the hole in the pulley hub as I don�t like altering the pulley so make a new stepped pin on my lathe with the pulley side same as original & sleeve side to fit the drilled (enlarged) hole in the operating sleeve..
Don�t just re-assemble with a new production pin if the hole in the sleeve is worn as you gain nothing.. That sleeve must remain centered for that clutch to snap in properly..
Clooney
JDMAN60
01-27-2005 09:22:17
 Re: 60 Clutch pulley problem in reply to Clooney, 01-27-2005 06:10:28
Clooney I work in a large fabrication shop we have cnc mills and lathes so my plan was to bring it in and have the machinist to over drill in the original location on the sleeve just big enough to true things back to round and then to make a step pin like you mentioned. I do not want to drill the pulley out. Also What is the best way to pull that gear on the pulley I made a 5/8" thick plate to set in the middle of that opening for something to put the puller against, but the gear does not seem to want to move. I do not like to use pullers like that on gears it seems I always make things worse when something breaks. Thanks Willy
Clooney
01-27-2005 10:19:38
 Re: 60 Clutch pulley problem in reply to JDMAN60, 01-27-2005 09:22:17
Willy, on pulling those gears?.. I use either a big bearing splitter & my arbor press or a large 3 jaw gear puller (very large).. Once pulling force it put on the gear I use a torch & apply heat to the gear until it starts moving,, then increase the pull until it comes off.. Without heat they usually won�t budge (or at least I�m afraid to apply that much force)..
You must be careful when pressing the gear back on & be sure to support under the center hub on the pulley or you risk cracking the pulley (don�t just rest the pulley on the outer rim of the pulley)..
It sounds like you have a good plan on that pin..
Check the pins, pin bores, & pulley ears that those 3 pivots ride in.. Those pins & pin bores wear oblong & cause major engagement problems also.. Again BE SURE to drill those pin holes back to OTIGINAL CENTER or risk poor snap in..
Clooney
Mike M
01-27-2005 09:57:47
The best way to pull that gear is a large 3 jaw Hydraulic gear puller. I picked up a gear puller attachment that fits on my porta power it is the cats a$$. When pressing them back on support the inside on the center so you don't break the pulley. If you heat up the gear so spit sizzles on it I've had them fall on when I dropped the press plate on them getting ready to press.Make sure you have a key in place and line it up good and that the gear goes on all the way.
Clooney
01-27-2005 09:44:14
Clooney
Mike M
01-27-2005 05:14:09
They just press in. Some you can get out from the other side and some I run a die down them and thread them this way you can use a stack of washers and a nut to pull it up out.
