JD B's rear rims
BIGJAKE
01-26-2005 19:30:59
my dad just bought a '41 B it has pressed steel rims on the rear could this be the factory rims ??? thanks BIGJAKE
Jason Z in MO
01-26-2005 20:26:25
 Re: JD B's rear rims in reply to BIGJAKE , 01-26-2005 19:30:59
They most likely are. I have stamped steel rims on my 40 B. The part number should be stamped on the outside (side opposite the rivets) between two flutes. Just looked at mine.
From the parts book:
8-38" - JD1250R
9-38" - JD1249R
10-38" - JD1253R
11-38" - JD1260R
Duane Larson can provide a lot more information about wheels.
Duane Larson
01-26-2005 20:16:17
BIGJAKE,
Yes, pressed steel wheels were available on B's starting at 81793 (early in the 1940 model year).
Jason Z in MO
01-26-2005 20:42:34
 Re: JD B's rear rims in reply to Duane Larson, 01-26-2005 20:16:17
Guess you and I were responding at the same time!
Hope you are doing well! You going to Waterloo in Feb?
Duane Larson
01-26-2005 21:07:10
 Re: JD B's rear rims in reply to Jason Z in MO, 01-26-2005 20:42:34
Hi Jason,
Yes, that happens to me, too. Thanks for the good words. No, I won't be in Waterloo - our grandson is being baptized that weekend in NC, so that is more important. But I would be there if I could.
Duane
