6.125 pistons in R
dirrtclodd
01-26-2005 15:46:26
I have a set of .045 over piston's out of a 730D. I know you can bore the R out to 6.125 without a problem, but will the extra .045 be ok. Thank's.
jbul
01-27-2005 17:44:06
 Re: 6.125 pistons in R in reply to dirrtclodd, 01-26-2005 15:46:26
Sorry I guess you would need that, I will try to help, I"m on line almost every nite about 10:00 on.
[email protected]
or ask here maybe someone else will help too.
joe
Gpower
01-26-2005 16:25:02
Yep no problem
dirrtclodd
01-27-2005 14:56:25
 Re: 6.125 pistons in R in reply to Gpower, 01-26-2005 16:25:02
Can I get your e-mail to ask you question's about your R. Thank's.
jbul
01-26-2005 20:12:24
Don't forget you must change the injector tip to the 5 hole tips. The ones in the R are 4 hole and the angle of spray will not match the indent in the piston. Will run very bad and will wash out the cylinder wall. The tips can be gotten from deere and only the tips need be changed $50.00 each, just did it myself. I've done a lot of other hp items including stroke,pumps, & injectors I can help with info if you like. Word of caution do not push over 100 hp, no third main like the 820-830's make for a weak spot.
