old bones
01-27-2005 16:58:40
Re: Good first JD 2-cylinder? in reply to Tanklord, 01-26-2005 15:26:05
what you'll get depends on what your tractor fund is, obviously. condition of tractors being the same, B's will be cheapest, folowed by A's, followed by 50's, followed by 60's. A's and B's will be the simplest to work on, wheras the 60 will be more complex- i.e. power steering, dual venturi carb, live power. don't know much about 50's. i agree with Pat Browning- get one that runs, unless you get a real deal on a non-runner- you can sink a lot of cash in a non-runner, or you might get lucky. i bought a 48B 23 years ago for $100- needed tires, re-wiring, engine stuck. soaked the cyl's with wd40 for a couple weeks, broke free by hand. ran it for 13 years. bought a 49A for $100- hadn't been ran in 8 years, but shedded. put a battery in it, cleaned the carb, started right up. that was 7 years ago, and i painted it last year. good runner. use it all the time. last fall bought a running 60 for $900- have put several hundred in it this winter (clutch, radiator, carb kit, gauges, ign switch) and it's going to need paint this year. still a cheap tractor, but it's my winter hobby. my suggestion would be to find someone that knows the 2 bangers and have that person look at it with you (we really are friendly folks). could save you a lot. there are a lot of things to look for that an experienced eye will see right off. something that seems major could be minor, and vica-versa. besides, then you'll have someone to swap info with. just my thoughts, old bones
