4010D Fuel filter change
Mark / Wi
01-26-2005 12:20:35
I have a 1962 4010D with the over and under fuel filter system. I was told there could be problems with changing the fuel filters that may include having to bleed the injector lines. What hints could you give on how to do this and how would you bleed the injector lines if they needed it? Thanks in advance for your comments.
Chip
01-26-2005 16:52:51
 Re: 4010D Fuel filter change in reply to Mark / Wi, 01-26-2005 12:20:35
One filter can has a bleeder on the bottom, when this can is installed on the top filter the bleeder will be on top. Remove the bleeder bolt then pump the fuel pump manually until fuel comes out the top can (bottom of can) bleeder.Make sure the can to base seal is clean. I've replaced mine like JDBert,It's a cleaner setup.
JDBert
01-26-2005 13:59:00
On think on those setups they had a little problem with getting them to seal after changing. Just make sure you get a good seal and dont get the seal ring in there cockeyed and you'll be ok, you'll have to watch the rear of it the most. Otherwise to bleed the lines, you just LOOSEN them at the injector and either pump the primer or do it while its running. I changed mine over to the newer glass filters and it nothing else its a lot less messy.
