720D Injection Nozzle
Kevin L.
01-26-2005 09:23:52
Just started getting into putting the nozzles back into the motor and know there are pipes coming off the bottom of the injection nozzles. The 720D JD service & parts manual call them the leakoff pipe. I would like to know where the other end of the pipes go and the I&T also talks about possible leaking as much as 1cc per minute, my other question is where is the excess diesel fuel that leaks out suppose to go. Also wishing for an electronic version of the SM2028 "I think", the one about servicing diesel injectors and pumps.. thanks
Don Dittmar
01-26-2005 09:55:37
 Re: 720D Injection Nozzle in reply to Kevin L., 01-26-2005 09:23:52
More fuel is sent to the injector than what is needed for lube purposes. This extral fuel is then returned
Clooney
01-26-2005 10:26:17
 Re: 720D Injection Nozzle in reply to Don Dittmar, 01-26-2005 09:55:37
Don, what you said is true for some injection systems but not the (old) 2-cylinder Deere�s .. On the 2 cylinder Deere�s that is a bleed off pipe.
The injectors on the (old) 2-cylindrer Deere�s only supply fuel to the injector & pulse the injector open with one pressure line to each injector .. That second bottom line just plumbs any leaked off fuel that get by the injector plunger into the intake area to allow any (very small amount) of fuel that gets by the injector to get sucked up by the intake air & burnt.. If those bleed off lines weren�t there that fuel would end up in the engine oil..
I usually use a small amount of sealer on those lines where they push into the head holes so engine oil doesn�t get sucked into the intake through any leakage.
Clooney
Don Dittmar
01-29-2005 07:02:01
 Re: 720D Injection Nozzle in reply to Clooney, 01-26-2005 10:26:17
Sorry about that. I am not to familiar with the 2 cyld diesel systems, although I plan on giving myself a lesson when I get done on the AC i am redoing. I really like the sounds of those old deere 2 cylinder diesels. I am looking for a 730 to restore right now.
buickanddeere
01-26-2005 11:57:18
I've kicked around the idea of extending those bleed lines back to the fuel tank. I'm just not keen on anything that could possibly introduce something flammable into a diesel's intake tract. What are your thoughts..... ....?
Clooney
01-26-2005 12:10:29
 Re: 720D Injection Nozzle in reply to buickanddeere, 01-26-2005 11:57:18
Glen, why bother,, those things only pass a few drops per hour & why not into the intake as it will just enter the intake air & burn with the combustion process. If those bleed tubes pass much fuel you have serious injector problems & where it goes will be the least of your worries..
I�m not sure if trying to push that fuel clear back into the tank would work as it could impair the injector operation or pop off speed..
If it really bothers you to have a few drops of fuel enter the intake tract you could just route them out the bottom of the rocker cover.. That way if you started seeing some fuel there you would know the injectors need attention..
I have cranked a lot of 2-cylinder diesels with the injectors reversed & pointing forward for test proposes & can�t ever remember much if any fuel flowing from those bleed off tubes..
Clooney
Kevin L.
01-26-2005 11:49:30
No where in the manuals have they talked about where the leakoff pipes went and I had not looked at the top side of the head yet, but knew that the excess should not go into the pump chamber with no siphron to get it out or back into the fuel system and surely not into the valve cover back into the oil. Thanks for the replies..
Clooney
01-26-2005 11:58:19
 Re: 720D Injection Nozzle in reply to Kevin L., 01-26-2005 11:49:30
Kevin, just blow some compressed air into those head holes & you will hear right where they terminate.,.
Clooney
Kevin L.
01-26-2005 12:59:16
 Re: 720D Injection Nozzle in reply to Clooney, 01-26-2005 11:58:19
I have both bleed lines but not sure of the serviceable of them. Seraching JD parts they only list one of them in the parts, I am thinking that I could use that one in both cylinders but would have to rebend it to fit the other cylinder that JD no long stocks, but at $34 a piece also wonder if soft copper tubing or even car brake line tubing of the size would also be a good sub.
F-I-T
01-26-2005 14:19:17
 Re: 720D Injection Nozzle in reply to Kevin L., 01-26-2005 12:59:16
Kevin:
I had one out myself not long ago, and it sure looks like a piece of steel brake line to me. I'm sure copper would work if you could get it configured into the opening, but steel I think would be ideal. The glands are sweated on, so you can remove the old ones and reuse.
Frank
Mike M
01-26-2005 09:44:51
The other end of the leak off pipes goes into a hole in the cyl. head that leads to the intake port. I guess the excess helps lube the intake valve stems and then just burns up when it gets sucked in the engine. If you can find someone who knows these systems and has the proper test stand and sets the pumps and injectors up right and together it will make a noticable difference.
