Compression in lbs.
Hooked
01-26-2005 08:10:12
I need the formula for calculating compression in lbs. I'm having a distributor rebuilt with electronic igntion and hot coil, and one of the questions they asked is "What is the compression in lbs?" Does that mean foot lbs. of torque? The tractor is a 1948 A.
Thanks for your help
Lee B
01-27-2005 20:52:52
 Re: Compression in lbs. in reply to Hooked, 01-26-2005 08:10:12
The crude formula is air pressure times compression ratio equals compression pressure.
14.7 psi X 5.6 comp ratio = 83 psi
Other factors rapidly enter the picture to complicate the above simple formula to one that requires a best guess anyway. Compression in lbs means pounds per square inch (psi).
I&T manual shows 5.6 compression ratio with 110 lbs compression pressure which doesn't jibe with above formula. Either the compression ratio is derated quite a bit or someone's gauge is a tad off? I can see where you would get less due to volumetric inefficiencies, leakage and other complications but not MORE.
Ah... forgot to include the heating effect. Even at cranking speeds, the air would heat up to raise the straight calculated 83 lbs to the measured 110 lbs. This is where the guess work comes in too. I've a formula that uses exponents for this factor but I get some disagreement using it too. Even the authors of the book use a different exponent value when they want to without, it seems, any reason at all. Beyond this point, total confusion reigns and I'm not going there.
billde
01-26-2005 09:40:04
they are probably refering to Lbs/sq in {psi} Check this by removing all spark plugs, open throttle wide open, attach compression tester through spark plug hole crank engine over with the starter until pressure no longer increases. Do this on all cylinders. If you don't have a compression tester, any auto supply store should have one. If you are going to do this very often I would suggest buying the kind that screws into the sparkplug hole.
RalphinWI
01-26-2005 09:02:48
The cranking pressure for late A's was 110 lbs/(sq-in) - i.e. psi. This assumes is is a gas, without higher compression pistons or a milled head.Sears used to carry a gauge with which you could measure the compression pressure.
Bob
01-26-2005 08:28:18
I would assume "compression in lbs." means remove the spark plugs, open the throttle, install a compression tester in one of the spark plug holes and crank 'er over, and get an actual compression reading.
