4010 PTO pins
Lyle
01-26-2005 02:53:21
The PTO shaft bolts come loose on my 4010 and I believe that I sheared the pins on the 540/1000 shifter. In the archives they talk about that it is possible to just lock it in the 540 and forget about the 1000 which I never use. My question is first is this a good idea and second how do you do it. Thanks Gary
Tx Jim
01-27-2005 03:37:32
 Removal of 1000RPM gear in reply to Lyle, 01-26-2005 02:53:21
As I posted earlier if 1000 rpm drive gear is removed and pto shaft is shimmed for width of gear it will work. 1000 rpm is no longer an option on this tractor.I did several back in the '80s and I had no compaints.I got the owners approval first.They liked the idea of no more pins to break/bend.Tx Jim/[email protected]
gwece
01-26-2005 12:08:08
 Re: 4010 PTO pins in reply to Lyle, 01-26-2005 02:53:21
Same thing has happened to me twice over the years. Last time I had the pto shaft tapped out to the next biggest bolt size and drilled out the pto stub shaft to match. Since you must split the tractor to repair the 540 pin, if it happens again I will look into locking in the 540 and locking out the 1000.
Do a search in the archives for "Margaret" and look at Tx Jim reply about how he did this years ago when working for a deere dealer.
Would be nice to get an expert opinion from one of the experts on this forum (Clooney, GMan, JohnT, etc.) as to whether or not it is a good idea mechanically to lock out the 1000.
Good Luck!
twopop
01-26-2005 11:30:42
if you bent a pin,it is the 540 pin.the 540 pin has to be replaced and you need a repair manual.the tractor has to be split.you could ues the 1000 w/o splitting.it is a detailed explanation on how to do the repair.
