2010 Power Steering Motor - how to take off
Cash Moline
01-25-2005 19:21:48
My shop asked me to ask here if there is a trick or special tool to get off the power steering motor that sits in front of the radiator...they thought it also may be called the ps assist motor? They are having a hard time figuring it out they said. Or if you have any manual suggestions that detail the 2010 power steering that'd be appreciated too since the 1010 / 2010 John Deere tractor repair book they have doesn't cover much of it. Thank you.
turk
01-26-2005 18:16:10
 Re: 2010 Power Steering Motor - how to take off in reply to Cash Moline, 01-25-2005 19:21:48
No special tools, It is just a tight fit. I loosened the bolts 1/4 inch, and hammered on the heads to get enough space to get pry bars under.
Goes together tight too. I had to draw it into place with the bolts
Cash Moline
01-26-2005 17:09:39
Yes this 2010 is a 2010 R diesel narrow front with power steering on it. Serial 15006 so that is a 1961. Thanks.
Cash Moline
01-26-2005 08:51:16
Hi...I will get the serial # tonight and tag letter designation. It is a 2010 Diesel narrow front tractor and we are taking this power steering assist motor off it to put on a 2010 utility wide front end...we know it is off a 2010 RU. But the problem is the shop can't figure out how to get this motor off or if there's a special tool. Thanks for your help.
[email protected]
msb
01-25-2005 21:18:54
Row crop or Row crop Utility model?
