70 radiator
Pete1468
01-25-2005 18:49:11
Can you get a replacement new radiator for a 70 gas? I was going to paint my only John Deere on the farm, power washed it off and low and behold a leak was spotted at the bottom of the radiator. I took everything off and it"s ready to be taken out of the tractor, just need some ideas for either getting this one fixed or getting a different one.
Fred Wolfe
01-26-2005 13:21:19
 Re: 70 radiator in reply to Pete1468, 01-25-2005 18:49:11
Email, [email protected] for JD 70 gas radiator.
rickm
01-26-2005 12:27:08
Pete, new cores are available through many places and maybe even here on YTM. I was only going to suggest that, while you have it off, don't make the same mistake that I did...
Spend the time to examine the water pipes, replace the hoses with new and overhaul the water pump (even if you don't see any problem with it.)
old
01-25-2005 19:31:00
Yes value bitl has them for around $300
Harold R
01-25-2005 20:55:21
 Re: 70 radiator in reply to old, 01-25-2005 19:31:00
Pete , Had my 70 painted in a auto body shop, They got to close to the rad with the sand blaster and it sprung a bad leak . Poured a big jar of Bars Leak rad seal into the rad just to get it home and it hasnt leaked a drop since. [Three years ago] Its worth a try as I have used it with good results on other tractors since. ____-Harold
