hard shifting
johndeereman
01-25-2005 16:50:35
i have a 43 jd b when i put in 5&6 gear it goes all the way in gear but the shifter is not all the way over all the other gears it goes all the way over prob a bad bearing would like to hear youre input before i tear it apart maybe it has an adjustment or something thought it might be the subzero temps but i put it in garage with heat all night and still does samething
Clooney
01-26-2005 06:25:40
 Re: hard shifting in reply to johndeereman, 01-25-2005 16:50:35
johndeereman, yes, you could have a bad trans bearing, or bent shift fork,, or misadjusted shift rail,, or twisted sliding gear shaft.. Or any number of other trans aliments.
About all you can do is pull the trans top cover & find out what the hang up is..
Clooney
