Engine Rod Knock 620
Popper Dick (L
01-25-2005 13:42:13
Last fall, I performed the normal maintenance on my 620 John Deere, change the oil, lubrication, etc. within 30 minutes after changing my oil, I developed a rod knock. I shut the tractor down and put it away in the garage. I have been on Johnny poppers it since I was eight years old, and now I am 68. In all of that time, I have never been inside of one of these engines or transmissions. A couple of years ago I purchased the service manual and the parts manual from John Deere. The service manual that was available from John Deere covers the 60 series tractor and was published in 1952. I sat down today to research the proper way to tear down the engine to gain access to the connecting rods and crank journals. I wanted to start at that point, to see if I can locate the problem. The tractor always starts immediately, regardless of the weather, whether it be cold hot or wet. It starts perfectly every time runs excellent and has great power. Also, it does not have any oil leaks. I thought I would try and see if I can deal with the rod bearings only at this time. I realized that that seems like I'm cutting corners, and I'm sure that it is in the minds of most of you. My work schedule just does not permit me to spend the time on a complete 100% restoration at this time. As I said above, the tractor runs great and has great power, good oil pressure, no oil leaks, and I am very happy with it. My clutch operates very solidly, and I checked for side play on the crankshaft. And I find absolutely no side play at all one way or the other up or down back and forth or side to side. I have no whining noises of any kind.
So that said, that is why I would like to look into the rod bearings and crank journals at this time. As I read through the service manual, there is no mention of removing the governor and hydraulic pump. The instructions go directly from removing the manifold and cylinder head to taking off the crank case cover and disassembling the connecting rod bearing caps from the rods. Not ever doing this before, I decided that I would remove all of the bolts holding the governor and hydraulic pump from the top of the crank case casting. I then thought that I would slide the governor and hydraulic pump rear word to disconnect it from the fan shaft and remove it to gain access to the crank case cover. I am aware of the fan shaft coupling, because last year, I rebuilt my power steering pump and had no problems. I realize aligning it back up can be quite tricky.
I thought before I do all of these things that I plan on that I would consult with you guys that have been there before, and except your constructive criticism. Am I about to rain on my parade or is this an acceptable way to gain access to the crank case cover on my model 620? I would appreciate any comments that any and all of you would be willing to share so that I go about doing this the correct way. You never get too old to learn.
Again, thanks for any and all help.
Popper Dick
ChuckW
01-26-2005 08:38:16
 Re: Engine Rod Knock 620 in reply to Popper Dick (Long Post), 01-25-2005 13:42:13
I've been studying this post and believe you need to really check out location of noise. From your description, I have trouble believing a rod bearing would be loose enough to know, if so you would have probably trashed out the crank. I have heard of a side knock to the crank but this generally doesn't do any damage. Before I tore that thing apart, I'd try to get another head involved as you may be overlooking a simple problem. I know I've done some brain surgery on some simple things and could have kicked myself. These old tractors are tough and generally don't just immediately do anything like you described. If you had a loose bearing you should be able to feel off the flywheel by movement back and forth. Of course in life there is a first for everything. You can take the cover off and feel of the rod and see if has movement. That would be my first step.
Clooney
01-26-2005 05:55:59
Dick, that rod knock showing up right after an oil change is suspect..
Are you 100% sure you added the oil back into the correct fill hole?
I guess if you are SURE it has oil in it then does it have good oil pressure? If no (or low) oil pressure suspect a bearing problem.. If you have good hot oil pressure then suspect something has come loose like a flywheel (it sounds like you have already checked that),,or the clutch driver disk (common & will sound just like a bad rod bearing)..
If your knock is actually coming from the engine internals first remove the crankcase cover then reach down inside & place your hand on one rod at a time (between the rod cap & crank throw),, then rock the flywheel back & forth if you feel excess play you have found your problem (you won�t have a knock if you can�t feel play),, then do the same way up in the piston at the top of rod to the piston pin boss (that will show wrist pin slop)..
You can check the mains by lifting or jacking up the flywheel or engaged clutch pulley & looking for excess vertical movement.
If your oil pressure is low suspect the oil filter head is broken if you over tightened the oil filter lower cover when you changed the oil (that is common if the filter lower cover was over tightened)..
The 60�s had some crankshaft breaking problems but I haven�t seen much of that on the 620�
Try to eliminate ALL the external noise sources before tearing that engine down.. Once apart a noise causing area is very hard to find unless there is a major malfunction of a part..
Clooney
ChuckW
01-26-2005 04:06:04
I've taken off the shifter cover on 520/530 to better access the engine cavity. However a friend of mine has overhauled many of these without taking off anything. You have to use bent wrenches and work with a limited space but it is a heck of a lot easier than tearing down the hydraulic pump, etc. I would pull the battery cable before working on unit. Concerning your noise, rod bearing sounds questionable. If it is knocking that loud and is a rod bearing you have other problems. You should be able to pull the flywheel cover and rock wheel and see if there is any play or movement. I'd go slow in tear down and you may be barking up the wrong trees.
Popper Dick
01-26-2005 05:27:22
 Re: Engine Rod Knock 620 in reply to ChuckW, 01-26-2005 04:06:04
Thanks Chuck,
My flywheel cover is off. I have done everything I can think of to rock the flywheel to find problems, but so far everything is tight and clean.
Thank You
Dick
730-LP
01-25-2005 19:47:38
Popper before you tear it down pull the clutch cover and take out the bolt that holds the clutch driver thats in the end of the crank. The cluch driver may be loose on the crank.
Popper Dick
01-25-2005 20:11:21
 Re: Engine Rod Knock 620 in reply to 730-LP, 01-25-2005 19:47:38
Thanks 730LP, for your reply.
I should have mentioned in my original post that the first thing I did was to take that bolt out and check the driver disk and put it back in tight. Everything I check on this tractor is in great shape. I was just hoping for an easy fix and I hoped to find it in the great resource of people on this forum.
Thank You Very Much
Dick
Hilltopper
01-25-2005 17:04:54
I have chased those knocks all over the tractor and i always find it is the flywheel loose. Pull the flywheel nut and see if the flywheel is not rocking back and forth in the splines instead of in and out.It may be hard to see.
Popper Dick
01-25-2005 17:53:27
 Re: Engine Rod Knock 620 in reply to Hilltopper, 01-25-2005 17:04:54
Hilltopper,
I just went down and removed the flywheeel nut and all but pulled my shoulder joints out of socket trying to get the flywheeel to rock, move, wiggle or anything. All I could get was .004 to .005 endplay movement. That flywheel is solid. I am at a lose as to what it might be short of rod journals. I sure wish you are right but I can't seem to find the flywheel loose.
Thank you so much for your input. If you have any more thoughts please shoot that at me.
Thanks so much to all of you guys.
Dick
gusc
01-25-2005 15:53:04
I agree with Mike, I sure wouldn't start assuming it is actually a rod knock, it could be lots of things. Also a rod knock would come on gradually, low at first, not all at once.
It could be something in the clutch hitting the housing or the water pump hitting the housing, could be the generator, lots of things can knock. Remove the fan belt and see it if is still there.
I once had a "rod knock" in a '40 Buick that turned out to be a split fan belt hitting the belt cover. In those days the belt was covered by a sheet metal cover. I was on my honeymoon and sure didn't need to overhaul the engine just then!
Mike M
01-25-2005 15:38:04
That seems very strange it would pop up that fast ? Pulling off the governor housing should not be needed,the hyd. pump maybe.You should be able to pull off the top cover without removing anything else. I would only remove enough other stuff AS NEEDED to gain access with a wrench to the rod nuts.Getting the hood off may end up giving you the most room.First off I would check the fylwheel bolts and make sure it's tight as a slightly loose fylwheel can sound just like a rod. I would also try shorting out each cyl. one at a time to try to find out which side it is on if it is a rod. One other thing that can make a noise on those 20 and 30 series is that the pistons come all the way up to the top in some areas and if a carb. screw gets sucked in or if a piston top ring breaks and works it's way into the top of the piston they will also knock. I have seen both of these happen.
Popper Dick
01-25-2005 16:41:20
 Re: Engine Rod Knock 620 in reply to Mike M, 01-25-2005 15:38:04
Mike thanks for the reply. I have the hood/tank off and the water drained ready to go already. Using a stethoscope by me and others find that it is deep in the journel area and very pronounced. I agree it came up pretty sudden. There is no way I will be able to gain access to the rod journals with the pump in the way. It might be less re-assembly problems if I remove just the pump.
Thank you for help
Dick
Mike M
01-25-2005 19:48:09
 Re: Engine Rod Knock 620 in reply to Popper Dick, 01-25-2005 16:41:20
since you have the hood and tank off and if you get that pump off that should give you as much room as you can get. You can pull off the rod caps and have a look if it's something real serious it may be easy to spot.Try to look up at the top end of the rod for a loose wrist pin bushing.You could try plastic gauge on those journals but it is hard to use on these as you can't turn the crank with it in while tightening.
