MH, If its a JD having more than 2 horizontal cylinders (heard they made something like that) I have little experience, but thats never stopped me from tossing out a few ideas until some 2020 guys get you going. 1) If possible when she starts and is doing that, one at a time do as you mentioned in removing plug wires to see if you can determine which cylinder is the culprit. HOWEVER when you do that remove the wires only a slight distance away from the plugs terminals and see if that cylinder starts to fire when the spark has to jump that extra lil artificial gap you created?? 2) If holding the wire slightly off the plug makes that cylinder fire, I strongly suspect the spark plug is fouling out, so take a look and if any plugs appear burned or all oiled or carboned up, try a fresh set of plugs. YOU MAY JUST NEED NEW PLUGS ????? 3) If removing the plugs wire per above or even a new plug in the missing cylinder dont make her run, try wire swapping or other known good plug wires to insure YOU DONT HAVE A BAD PLUG WIRE ON THAT CYLINDER??? If the wires appear bad or cracked or worn or are old, try a new set of plug wires. MAY BE AS SIMPLE AS A BAD PLUG !!!!! If its not a plug or plug wire problem, To be safe and as a general tune up and maintenance procedure, ALSO TAKE A LOOK AT THE CAP N ROTOR to see if that cylinders inner tower or pickup is cracked or has a carbon trace or is gummed up or is different in any way from the others??? YOU MAY HAVE A DISTRIBUTOR CAP PROBLEM !!!!! !!!!! Also check the points for heavy gray oxide coat or if burned or pitted or carboned up badly and replace if necessary. ASSUMING ITS A POINTS, NOT ANY SOLID STATE IGNITION???? 4) If its NOT a plug or plug wire or any ignition problem causing what you describe, you may wanna check the compression on all the cylinders to see if the bad one or any others are much lower than the rest??? 5) If that one is low on compression (or even if its not) next thing I would take a look at is the valve train and rockers as maybe it has one thats hanging/stuck until she gets warmed and lubed up??? A dry compression check when cold and before start up (plus visually observe the valve action) should indicate if the bad cylinder has any hanging/sticking valves. 6) In the event its a sticking valve, a clean up in the stem area and decarbonization and other additives, such as Marvel oil or Rislone or a good detergent may help. I usually change the oil and add a high detergent oil PLUS a quart of Rislone and Marvel Oil and run her long n hot n hard to clean her up??? Hope this is a start until some 2020 guys get here, let us all know what you find, good luck n God Bless. John T
