Diverter Valve needed for 2stage blower on 318?
Jeff Malinowski
01-25-2005 05:39:26
So, I just picked up a really nice 47 Snowblower for my 318 Tractor. The manual says a Flow Diverter Valve is needed to prevent the rockshaft from rotating when operating the chute.
What happens if you don't put this on?
Is anyone operating without one?
I'd sure appreciate any advice.
Jeff
Bob
01-25-2005 08:45:52
 Re: Diverter Valve needed for 2stage blower on 318 in reply to Jeff Malinowski, 01-25-2005 05:39:26
There are 2 sets of hydraulic outlets.
One set, you use for blower lift. The other set is tee'd into the lines to the built-in rockshaft lift cylinder, so when you move the lever to reverse the turning of the chute, the rockshaft cylinder will reverse it's movement, too. The diverter valve blocks off the oil to the built-in cylinder to prevent this. You could install longer hoses to one side of the built-in cylinder, and connect them with a hydraulic coupler. For use with the blower, you could unhook the coupler, which would block off the oil to the rockshaft cylinder. This would be easier and cheaper than installing the diverter valve, but a little less convenient.
Jeff Malinowski
01-25-2005 12:29:36
 Re: Diverter Valve needed for 2stage blower on 318 in reply to Bob, 01-25-2005 08:45:52
I understand how the diverter valve works. But what happens without one? The Rockshaft will rotate, when you turn the chute.
Is that a bad thing? Are there more side-effects than this?
Bob
01-25-2005 13:41:43
 Re: Diverter Valve needed for 2stage blower on 318 in reply to Jeff Malinowski, 01-25-2005 12:29:36
There will likely be a delay in the movement of the spout each time you reverse it's direction, because it is probably easier for the unloaded rockshaft cylinder to move, than for the cable mechanism to turn the spout. It WON'T hurt anything, there'll just be an annoying delay sometimes, before the spout moves.
Jeff Malinowski
01-25-2005 13:59:36
 Re: Diverter Valve needed for 2stage blower on 318 in reply to Bob, 01-25-2005 13:41:43
Thanks for the advice.
I've been using a single stage with the hand crank. I think I can handle a small delay. If not, I'll install the diverter valve for next season.
Jeff
Bob
01-25-2005 14:04:00
 Re: Diverter Valve needed for 2stage blower on 318 in reply to Jeff Malinowski, 01-25-2005 13:59:36
Do you have the #47 blower? I have one with 430 mounts, wish I had the mounts to put it on my 318. If the #47 is what you have, it's really a big, heavy blower. How does the 318 handle it hanging on the front? I have never actually seen one set up this was, and have been curious.
