Leaking Heater Core 4230
Johnsdeere
01-24-2005 20:32:32
Well after replacing all the hoses and lines durring several different trys to heat my cab, I think I have found why they were disconnected. I thought I had it all set and throttled it up and got squirted with antifreeze in the head. I pulled the heater core out and it looks to be in good shape. I have a small pin hole in the middle of it. Should I replace it or have it repaired at a radiator shop? Deere wants $165 for it. Does any one know were to find a aftermarket one? thanks
david val
01-27-2005 04:01:15
 Re: Leaking Heater Core 4230 in reply to Johnsdeere, 01-24-2005 20:32:32
if the core is aluminum it may be hard to fix by a radiator shop you can try and fix it with epoxy on the spot witout disconnecting a/c lines (if there are any).
david
txblu
01-25-2005 06:35:12
If it is in a tube, a radiator shop can cut the tube and solder both ends or just do a mechanical weld to seal it off.
If it is a tank leak (assuming it's brass) a little solder and flux should do it.
Sorry your 4230 is letting you down. Just bought one and anxious to put it to the field.
Mark
RickB
01-25-2005 11:52:09
 Mark, I thought you were slumming over here in reply to txblu, 01-25-2005 06:35:12
But now you say you BOUGHT a Deere?
