AR Rearend grease
Tony W
01-24-2005 19:26:54
I am in the process of redoing a 37 AR unstyled and have removed the grease from the rearend and was thinking of putting oil back in. What/if, any oil should be put in (what weight), or should one go back to grease? It will be a tractor that will be used lightly with little pulling. Thank you
Clooney
01-25-2005 10:18:13
 Re: AR Rearend grease in reply to Tony W, 01-24-2005 19:26:54
Tony, that rear gear & trans area used gear oil & not grease.. If it has grease in it now that is probably just old gear oil that is dirty & thickened due to use & age..
Clean as much of that goop out as you can then use GL-1 _90 weight gear oil if used in real cold weather as a work tractor-- or GL-1 _140 weight if for warmer weather use or just for parade duty.
While in there you should replace the real axle inner oil seals as those will more than likely leak like a sieve when gear oil is put back in that rear housing..
Clooney
Tony W
01-26-2005 05:05:55
 Re: AR Rearend grease in reply to Clooney, 01-25-2005 10:18:13
You are correct, it was some kind of thick gunk. It would not drain out of the drain at all. Had to take the back off and clean it out. Thank YOu for the info.
Tony
