1936 A air cleaner question
greenmech
01-24-2005 18:29:13
Does the disc inside the oil reservore, part # AA394R disc with handle, lay in the oil or held up with the spring clip? Thanks Ron Mn.
DDW
01-25-2005 04:55:10
 Re: 1936 A air cleaner question in reply to greenmech, 01-24-2005 18:29:13
Greenmech, in the air cleaner in my 1934 "A", that cover rests convex side up on a ridge in the oil container. The spring clip goes above it to hold it in place. I believe the oil level should be such that most of the disk cover is covered with oil. The oil reserve should be level with the hole in the top of the disk. Right or wrong, thats how I have mine set up and it seems to be correct from what I've seen!
David
greenmech
01-25-2005 19:12:12
 Re: 1936 A air cleaner question in reply to DDW, 01-25-2005 04:55:10
David , thanks for answering. I don't seem to have that ridge to hold the disc or the disc is too small. We'll make it work somehow. Ron Mn.
