4430????
ToddLevi
01-24-2005 11:17:08
I am thinking of buying a 1977 4430.What should I look out for?What are the good and bad points of them?Thanks.
Leo Crall
01-24-2005 18:35:33
 Re: 4430???? in reply to ToddLevi, 01-24-2005 11:17:08
My understanding is that the later year 4430 tractors had an upgrade to the drive train. I would think that a 1977 would have the later version. Maybe someone else can confirm this.
John in Md.
01-24-2005 15:22:44
Make sure it starts good , they should start easily if nobody ethered the rings out of it. If it's a quad check the C and D ranges for slippage and jumping out of gear. If powershift make sure it's not slipping in higher gears. If it's a Syncro cut the price by 30% and look for another machine. Make sure compressor is good on the A/C look up in the corner of the cab where the A/C lines go up and see if it's full of chaff and junk (this is where A/c lines seem to rust thru). Ask if it's been rebuilt or has any blowby , maintenance records etc.
Lyle
01-24-2005 11:34:40
Hi, spent a few hours on the 4430 as a youngster.
1. Thirsty on fuel when working hard.
2. Tend to be hard starting motors compared to either the 20 or 40 series deeres. The local store selling canned ether starting fluid will get to know you on a first name basis, especially if you plan to use the tractor in colder climates.
3. The sound guard cab on the 4430 is definately an improvement on the cabs we had with my dad's 4020's.
If you have a choice for the same money, you may want to try and find a 4240 or 4440.
charlesmm
01-25-2005 08:07:33
 Re: 4430???? in reply to Lyle, 01-24-2005 11:34:40
that model will have the stronger axle and many other upgrades , in fact you are getting a virtual 4440 at a lower price , same power but slightly less torque . plenty of comment in the archives , almost all very positive , with tests for the powershift or quad . very popular and a future classic
John Jenkins
01-25-2005 10:50:27
 Re: 4430???? in reply to charlesmm, 01-25-2005 08:07:33
We have a 4430 synchro and a 4440 quad-range. While they are both fine machines, the 4440 could drag 2 4430s around backwards. The power differential between those two is actually quite steep. Maybe our 4440 is just one of those �special� tractors you see from time to time but I do know the engine and fuel specs are bone stock and yet it can outpull the h3ll out of the 4630 it replaced. Not dissing the 4430...it�s an absolute dream to drive but it�s no 4440.
thurlow
01-25-2005 12:40:49
 Re: 4430???? in reply to John Jenkins, 01-25-2005 10:50:27
Interesting statement..... a little hyperbole/poetic license? Will the 4440 REALLY drag two 4430s around backwards..... will the 4430s be running/pulling? Interesting statement!!
John Jenkins
01-25-2005 13:51:57
 Re: 4430???? in reply to thurlow, 01-25-2005 12:40:49
Okay, so I embellished a bit. The 4440 is still a far superior tractor. Like said before, however, the 4430 is still an excellent machine and if you don�t need the extra power, usually much cheaper than a 4440.
G/MAN
01-25-2005 10:55:41
I'd agree. The 4430 was a good tractor. The 4440 a great one. The 466 engine alone put it head-and-shoulders above the 4430. And yes, a good 4440 is easily as much tractor as a 4630. More if you get into things like cab comfort, as the 4440 was available with the Hydracushioned seat. The 4440 also has an improved intake system with the air filter under the hood instead of taking up space in front of the radiator. I have nothing against the 4430, but even though they're more $$$, I'd rather have a 4440 any day of the week.
John Jenkins
01-25-2005 11:22:08
 Re: 4430???? in reply to G/MAN, 01-25-2005 10:55:41
10-4 G-Man. I�ve never run a 4440 (or 4430 for that matter) with a cab (ours are both 4-post) so I can�t speak about the cabs but like you said, aside from power and drivetrain/hydraulics, there are several other minor differences that make the 4440 a better machine.
