3010 lift arms
BradB
01-24-2005 10:58:09
The lift arms on my 3010 settle down when the tractor sits. I would like to fix this. Mechanic told me to wait till I needed a new clutch? I think this can be fixed without spliting the tractor. Someone said to go in behind the seat to replace an O ring? I will have to see if this fix is in the IT manual. I have the tractor in the shop now and have time to do the repair. Any advice? And I thank you as always.
msb
01-24-2005 19:53:06
 Re: 3010 lift arms in reply to BradB, 01-24-2005 10:58:09
Usually settling of 3 pt arms are from one of two causes.The most likely is that O ring. There is an oil line that takes an 11/16" wrench ,I believe.Remove the short line and then remove the 4 ,3/4" capscrews and pull the cap out of the bore.Raise the arms up with your hand and shove the piston all the eay back in the cylinder.Quickly push the arm down and the piston should pop out. Look for any rough or damaged place on the O ring. Also inspect the cylinder bore for any scoring or damage.Replace the O ring even if you don't see any damage.Use plenty of grease on the new O ring.Then reassemble the cap and oil line.
The other cause could be a malfunctioning thermal relief valve.Let us know if the new O ring doesn't solve your problem.
BradB
01-25-2005 07:33:25
 Re: 3010 lift arms in reply to msb, 01-24-2005 19:53:06
MSB,
OK thanks I think you told me this before but I lost the post. I will print a copy of this and go to work on it.
