JD 2130/2640 Questions re: Steering and Hydraulics
Lyle (Sask)
01-24-2005 08:30:34
First, I have to say that with the winter we are having up here, I'm enjoying the heck out of the seat time on our 1975 2130 diesel. My neighbour and I co-own "Little John" and with the 148 loader and a rear mounted single stage snow blower, he's been racking up the hours keeping our acreage yards and driveways clear, and putting out round bales for the horses.
Questions:
1. There is a bolt on the lower left side of the console below the steering wheel. We seem to need to tighten it daily as it works loose when using the tractor and introduces a significant amount of play on the steering. The bolt currently has a flat washer only, can I add a lock washer to it ? How much torque should be applied to tighten it ?
2. The feed lines from the front pump to the rear of the tractor are seeping fluid. Approx. how much does it cost to replace them with proper Deere parts ? For a cheaper alternative, can I get custom soft hydraulic lines made up with the right fittings ? what diameter to use ? 1/2 " ? or 3/8 " ?
Thanks in advance for your help ...
Lyle.
david val
01-27-2005 05:11:21
 Re: JD 2130/2640 Questions re: Steering and Hydrau in reply to Lyle (Sask), 01-24-2005 08:30:34
tighten bolt then remove bolt and washer. if the inner shaft end is on the same level as the arm, then the arm needs to be replaced. if the shaft end is below the arm, then a new grade 8 bolt with matching hard washer (obtainable at deere) and tightening a few times to 240 ft/lb will do the job.
david
Tx Jim
01-25-2005 04:14:34
Lyle,the bolt your refering to holds the bellcrank to shaft in bottom of steering valve.It's been long time but I think the shaft is taper splined.I would remove bolt,loc-tight and put some good torque on bolt.I don't know correct specs.If that doesn't hold next would be replacing bellcrank.Tx Jim
Tx Jim
01-25-2005 04:23:09
 Hyd. lines in reply to Tx Jim, 01-25-2005 04:14:34
Lyle,lines coming from frt. pump have a round bushing like thingy on the end that sticks in clutch housing sealed by o-rings.This would make putting hyd.hoses on instead of steel lines a little difficult.Tx Jim
Lyle
01-25-2005 11:22:25
 Re: Hyd. lines in reply to Tx Jim, 01-25-2005 04:23:09
Thanks for the info. I appreciate your help.
Lyle.
