3020 powershift slow reverse
jdjack
02-14-2004 16:26:49
Have a early model 3020 gas with a powershift.When cold (50 degrees or below)when put in any reverse speed, tractor whats to go foward, push in clutch and let out it might backup. So times it backsup very slow or won't move, engine doesn't labor, just keeps steady rpm, like it's slipping.
When tractor gets warmed up, reverse works much better. Have good clean fluid, and filters, and checked screen. All foward gears seem to work good. I am thinking that there is a valve sticking somewhere. Anybody else has any ideas or had this concern before. Thanks for anyadvise.
This is our main tractor.
Mike w J
02-15-2004 08:42:05
 Re: 3020 powershift slow reverse in reply to jdjack, 02-14-2004 16:26:49
When you put it in reverse bump that shift lever to the left in its slot if it is like our 3020 the shifter is wore and sometimes it just don't go into reverse until bump the lever ther is also a 1/4 inch pin that goes threw that shift lever that can break off and cause your problem you can see that pin if you look down into the shifter Hope this helps let us know
