Cam to oil pump Gear back lash
BUDD
02-14-2004 16:23:42
What is the proper setting for the cam to oil pump gear? I installed a new cam and cam bearing but not sure what this setting should be. I would assume that this should be very little back lash, maybe just enough that you can see there is some but no more, does that make sense?
Thanks for your help BUDD
Clooney
02-15-2004 07:18:41
 Re: Cam to oil pump Gear back lash in reply to BUDD, 02-14-2004 16:23:42
Budd, what are you working on?
BUDD
02-15-2004 07:42:41
 Re: Re: Cam to oil pump Gear back lash in reply to Clooney , 02-15-2004 07:18:41
Clooney:
Sorry and I new better, It is a 49 A
Thanks BUDD
Clooney
02-16-2004 03:08:28
 Re: Re: Re: Cam to oil pump Gear back lash in reply to BUDD, 02-15-2004 07:42:41
Budd, there isn't much you can do about changing the pump drive gear to cam gear lash.. As long as it isn't binding or tight it will be good to go..
