Greg A, there are usually a few things can cause a problem like your sticking starter.. The usual cause is the solenoid plunger sticking part way in due to old sticky cold oil or rust build-up.. If this is the first time it has happened maybe you just picked up some moisture in the starter & the moisture has turned to ice crystals.. As you have determined, the starter must come off to access that solenoid.. Another rather annoying occurrence on the 30 series tractors is the starter�s nose cone cracking.. I hope that isn�t the case as that is expensive.. Another thing that can happen is the big starter cable moved on the stud & is now contacting either the solenoid�s little initiation stud or the wire coming down from the push button.. I guess if it were my tractor & the loader had to come off to get the flywheel cover off I would first pull the lower starter well cover & see if their is any moisture or ice up inside the starter cavity.. If so maybe a little heat from a blow drier will help that area out.. (possibly you have plugged drain holes in the lower starter cavity cover from dirt or oil or ice).. Then make sure the battery cable isn�t shorting out to the starter solenoid�s starting stud (that will make them motor all the time) Maybe even spray some WD-40 up into the starter�s nose cone from the bottom..
I suppose you could have a problem with the dash starter button but those usually fail to (not work) & usually don�t stick in the on position.. I guess while you are under the tractor see if removing that wire from the starter solenoid makes it quit motoring.. If you can�t find or repair the problem from that bottom cover removal then you will have to pull the flywheel cover to get that starter out as the bolts are behind the flywheel .. Hope it�s just a moisture / ice problem as that will be easy to repair without pulling the starter out..
Clooney
