4010 clutch job
JD jim A.
01-23-2005 19:20:58
How do you remove the throwout bearing and PTO operating bearing? How do you install the new bearings? I'm afraid that I wouln't be able to tell if I have the new bearings fully seated. Any other tips or things to watch out for?
msb
01-24-2005 20:20:51
 Re: 4010 clutch job in reply to JD jim A., 01-23-2005 19:20:58
Ordinarily the bearings can be reomoved by hitting the backside with a brass hammer.The clutch throwout bearing should be rather easy to knock off.The PTO bearing might come a little harder.Be careful that you don't knock the operating sleeve out of the clutch operating collar.If you do you will have to swing the center section to replace it.Be sure to install the bearings so the grease can get to the inside of the bearings.Pack the PTO bearing with grease before you install it.
Jim B in AK
01-23-2005 22:51:06
I had my 4010 overhaled and they put the cluch in backwards and broke the dif/trany housing. That simple mistake cost me 6 months and $3,000.00 to fix.
JD Jack
01-23-2005 20:59:06
Not a bad time to replace rear main seal on engine, and the seal on the transmission shaft. They don't cost that much and are easy to do now. Also I don't know how many times I have seen it, but many people try to go without doing this only to have their new clutch ruined by a oil leak and end up replacing it again long beofre it starts to get wore out.
