3020 weeps oil
mikeinWA
01-23-2005 18:52:22
Began to notice a thin film of oily residue at weep holes on block of 3020. I have some time on my hands this winter and was considering sleeves and piston replacement. 4 out of five farmers recommend leaving it until its "real bad" because they fear a decomposition of grooves where o-rings seat in the block. I am not opposed to this approach, just seems like things only get real bad for me when I need them most. Any advice out there?
Bucksdeere
01-24-2005 15:33:19
 Re: 3020 weeps oil in reply to mikeinWA, 01-23-2005 18:52:22
Are you weeping oil, or is it anti-freeze?
Check to see if you have any anti-freeze in your
engine oil. If you have anti freeze in your engine oil all you can do is overhaul the engine.
If it is anti-freeze coming out the weep holes,
and as long as you do not have any anti-freeze
in your engine oil,
you can take a wooden dowel and plug the weep hole. If you plug the weep hole with a dowel
check your engine oil often to make sure you
do not have anti freeze in it.
I have seen people try this and it works,
sometimes for years.
Buck
JD Jack
01-23-2005 21:07:46
Its your call! If the O-ring grooves are bad the block is not a total loss! A local machine shop that specializes in engine rebuilds and a couple of reputable local mechanics I do business with told me that there is a third groove between the 2 o-rings. This is the weep hole groove. A third o-ring can be installed in this groove as long as the weep hole is tapped and plugged. They have said that they have been using this "fix" for years with no known problem cases. Or at least I hope so, as my 4020 is currently being rebulit and had one cylinder with a chunk of the bottom groove missing, and this method was used to fix it. The tractor is not running yet, so I don't have much personal experience with this!
mikeinWA
01-24-2005 09:27:38
 Re: 3020 weeps oil in reply to JD Jack, 01-23-2005 21:07:46
Thanks. Keep me posted on the rebuild if you have the time.
msb
01-24-2005 20:26:08
 Re: 3020 weeps oil in reply to mikeinWA, 01-24-2005 09:27:38
Sometimes what apperars to be damaged O ring grooves are simply not cleaned up real good.Use a small brass wire wheel on an extension to really clean those grooves up real good."Clean enough to eat off of."
