50 pipe
rej
01-23-2005 17:07:32
There is a pipe that connects to the top side air inlet above the oil bath and it runs all the way back and connects into the engine. When i took my carb off this small pipe came out of the engine fitting about 1/2 inch. What is the purpose of this airway and do i need to loosen the nut so this pipe will slide back in the proper place when i put my carb back on. There is no mention about this in my manual. thanks, BJ
Clooney
01-23-2005 17:26:02
 Re: 50 pipe in reply to rej, 01-23-2005 17:07:32
Rej, that is the ventilator pipe,, just push it back in..
If it won�t go, then loosen the gland nut on the end that won�t go back in & try it..
If it still won�t go in you might have to pull the nut & packing & slide it up the pipe a ways,, then install the pipe & push the packing back in,, then screw the gland nut in..
Basically it�s just a fresh air pipe..
Clooney
