70 live hydraulic pump noise
Randt Stoudt
01-23-2005 14:52:10
I just bought a JD 70 and put on my rear blade on to move snow. When I raise the blade the hydralics make noise like when there is air in the system. Even when the lever is in the lower/float position I can still hear a slight noise. When I use my JD 60 that system does not make these noises. Any help?
buickanddeere
01-23-2005 23:06:36
 Re: 70 live hydraulic pump noise in reply to Randt Stoudt, 01-23-2005 14:52:10
Is the noise at the pump, in one of the lines or somewhere in the PowerTrol? Can you describe the sound(s)?
Clooney
01-23-2005 15:01:02
Randt Stoudt, the first thing that comes to mind is the hydraulic oil is too thick. You might try changing to either 10 weight motor oil or Deere Hy-Guard fluid..
If it isn�t a thick oil problem then you could possibly be sucking air from a pump return line fitting or pin hole..
It could also have ice in the hydraulics (common if it sat for a while)
If that tractor had a remote cylinder(s) on it before you bought it there is a chance it is still set up for a one way remote.. If you tell me if you have a single or dual remote valve body I can tell you how to set that screw..
Clooney
Randy Stoudt
01-23-2005 16:30:18
 Re: 70 live hydraulic pump noise in reply to Clooney , 01-23-2005 15:01:02
Clooney, I just opened the lower pipe plug on the side of the Powr-Trol housing and the oil was about 30w and clean. I use 30w in my 60 and it works well with the 45 loader and rockshaft year around. If I had an air leak would there be signs of an oil leak? It could not have been ice as it was stored in a heated garage and made the noise immedately. I am not sure if I have a single or dual remote valve. It is a Powr-Trol with the two plugs in it that do not have NPT tapped holes for hydraulic hose. What does this screw setting do? There is no Baker valve for a second cylinder. Would too much side clearance in the gear pump cause this? This is the first time I used the YT forum and thanks for your help. I am a life long fan of two cylinder John Deeres and just bought my first diesel and expect to use this much more in the future.
Randy Stoudt
01-23-2005 17:23:17
 Re: 70 live hydraulic pump noise in reply to Randy Stoudt, 01-23-2005 16:30:18
My diesel is a 720. The 70 is a gas tractor. Sorry for the confusion.
Clooney
01-23-2005 17:44:00
 Re: 70 live hydraulic pump noise in reply to Randy Stoudt, 01-23-2005 17:23:17
Randy, if that is a 70 gas & the hydraulic pump (system) makes noise about all I can think of is:
Thick oil.. (you don�t seem to think that is it)
The system is sucking air (check the pipes above the oil level)
Your internal operating valve is misadjusted or partially plugged & causing a pressure build-up in the system..
One of the metal hydraulic lines is kinked or welded partially shut causing a restriction..
One of the pump seals is sucking air..
I really don�t know what to tell you from here..
I guess just let it run for a while at fast idle then feel the hydraulic pipes & if they are hot then you have a restriction causing a pressure build up in the system. If they remain cold you have other problems.
Clooney
Randy Stoudt
01-23-2005 17:59:24
 Re: 70 live hydraulic pump noise in reply to Clooney , 01-23-2005 17:44:00
Clooney, Thanks for the list of items to check. I will work on it. Randy
Clooney
01-23-2005 18:02:00
 Re: 70 live hydraulic pump noise in reply to Randy Stoudt, 01-23-2005 17:59:24
Randy, if you find something there please post back (or E-Mail me) as I would like to know what you eventually find�
Thanks�Clooney
Clooney
01-23-2005 16:48:42
Randy, you say diesel? Is this 70 tractor a diesel or a gas tractor? The pump is in a different place between the gas & diesel.
It sounds like you have the correct rear plugs in it & if no baker valve it is a single.
If the noise is there ALL the time it could still be thick oil.. But if kept inside & heated that probably isn�t the problem..
If a diesel those do make more hydraulic noises..
You might run it a while & see if the noise goes away somewhat as that will thin the oil out..
Any chance you have a hydraulic line with a loose clip or vibrating on the floor plate?
Let me know if is a diesel tractor?
An air leak won�t necessarily give you an oil leak if above the oil level..
Clooney
Randy Stoudt
01-24-2005 15:08:51
 Re: 70 live hydraulic pump noise PROBLEM SOVLED in reply to Clooney , 01-23-2005 16:48:42
After closer inspection I found that the small tube (pressure line ?) was vibrating when Powr-Trol was held in the full up position. I pulled off the platform to find that the band around the tube was rusted away and the tube serverly pitted. It is vibrating against the platform, transmission housing, and the return line.
