70D power trol pump oil lines
SL
01-23-2005 12:46:12
I am having a lot of difficulty getting the oil lines off of the power trol pump. My 70D has aftermarket flex hydraulic oil lines with what appears to be a JIC adapter to what ever is on there originally. In order to get a good wrench on the RHS smaller line, I had to remove 2 of the H shaped retainer bolts. Now when I wrench the whole thing rotates inside behind the H retainer so I cant get their adapter off for the JIC, or the retainer, or the LHS larger pressure line. What am I missing here? All the manuals show such a simple set up. I just want to remove these lines!
What do the oil lines hook up to and why would it rotate? Do I need to have the retainer on tight to hold what ever is inside the housing and moving?
Clooney
01-23-2005 13:06:18
 Re: 70D power trol pump oil lines in reply to SL, 01-23-2005 12:46:12
SL, I really don�t know what you are working with there with those aftermarket lines.. The original lines just pulled out after that �H� bracket was unbolted as the originals sealed with large flat rubber rings (like �O� rings).. That �H� retainer just held the original lines in the pump body..
Did you try removing that entire �H� bracket pulling on those lines pretty hard?
Clooney
SL
01-23-2005 17:40:59
 Re: 70D power trol pump oil lines in reply to Clooney , 01-23-2005 13:06:18
Thanks for your reponse Clooney. I know what you mean by it being hard to deal with whats not original.
I took a break and will start fresh. One thing I do think I see is some 'blue permatex in there'. I am going to have a glass of red and a nice dinner and put the grubbies bag on an see about getting that H off.
One question, were the original lines line an O-Ring Boss (ORB) type of connector? If so then there is nothing that should be holding it back once I get the 4 bolts off the H bracket.
Clooney
01-23-2005 17:49:18
 Re: 70D power trol pump oil lines in reply to SL, 01-23-2005 17:40:59
Sl, the original lines had �O� rings around the end of the lines & pushed into a shallow hole then the �H� clip held them in..
Clooney
SL
01-23-2005 20:07:47
 Re: 70D power trol pump oil lines in reply to Clooney , 01-23-2005 17:49:18
I got it apart with a pull, thanks Clooney.
Clooney
01-24-2005 06:03:26
 Re: 70D power trol pump oil lines in reply to SL, 01-23-2005 20:07:47
SL, you're welcome.. Isn�t it nice when things turn out to be easier than they first seem?.
Clooney
