Grease the flywheel ring gear on a 1947 A?
The other Bob i
01-22-2005 20:41:47
Has anyone else ever wondered if it might be a good idea to put a little grease on the flywheel ring gear? Would it slow down the wear on the starter gear teeth and possibly make the gears run a little better? or would it just collect dust and make it wear faster? I would appreciate any comments
BushogPapa
01-23-2005 06:36:26
 Re: Grease the flywheel ring gear on a 1947 A? in reply to The other Bob in Texas, 01-22-2005 20:41:47
If you do, use Dry Graphite or Dry Moly on the ring gear.. If it is Dry, it won't attract dirt, but it must not be a heavy coat or starter sticking may be a problem. I use dry moly and a "paint-on" graphite on my 3-point pivots..they stay lubed and yet don't attract dirt...and I don't have to get grease all over when I am near it..!!
Ron..
F-I-T
01-22-2005 21:06:06
I really believe it would just collect dust and increase the wear rate and increase the sticking problems.
Frank
Clooney
01-23-2005 04:29:38
 Re: Grease the flywheel ring gear on a 1947 A? in reply to F-I-T, 01-22-2005 21:06:06
Quote:--"I really believe it would just collect dust (dirt) and increase the wear rate and increase the sticking problems"
Frank, I totally agree with that...
Clooney
bojoe
01-23-2005 06:05:48
 Re: Grease the flywheel ring gear on a 1947 A? in reply to Clooney , 01-23-2005 04:29:38
I used to oil the chain on my 4 wheeler everytime I would ride it. A friend of mine never oiled his. I said why don't you oil that thing? He said if you oil it , it gives the dust and dirt a place to ride along all the time. If there is no oil/grease the dirt/dust falls on by and doesn't hang around. I keeped oiling mine and I would go through 2 chains to his one. Needless to say I don't oil any chains anymore. Like I always say."Good thought, Bad idea."
F-I-T
01-23-2005 06:49:16
 Re: Grease the flywheel ring gear on a 1947 A? in reply to bojoe, 01-23-2005 06:05:48
I know my brother-in-law said when they dirt biked in sandy conditions they would remove the lube from their chains for that very reason.
I was always amazed how long the roller chains on corn pickers and corn heads would last given the dirty conditions.
Frank
