39/40 B Steering Pedestal Crack - how to repair?
Jason Z in MO
01-22-2005 18:27:34
Working on an early styled B SN 81291.
Pulled the pedestal off and removed the steering spindle. Removed the thrust washer and found a crack in the pedestal casting. The crack begins at the lower bushing, across the thrust face, and around the outside of the casting. This is in the thick ring cast into the bottom of the pedestal. This area is a pretty thick casting.
Couple of questions: I am not a welder but can a qualified welder make an effective repair? I assume this should be repaired. Would I be money ahead to find a good used part?
This is my first restoration. I have worked on a lot of old iron but never completely torn down assemblies I *thought* were in good working order. I see a huge difference between restoration and a good paint job!
Jason [email protected]
Clooney
01-22-2005 18:44:13
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to Jason Z in MO, 01-22-2005 18:27:34
Jason, that�s a hard call.. You can�t just stick a welding rod in your buzz box & weld that crack.. It will need to be V�d out, preheated, welded, post heated, then probably peened to stress relieved.. Then will have to be metal finished to look like the original casting.. Probably will also need machining on the thrust surface too...
The cost of a decent repair will be high (at least in my area of the country)..
A good used would probably be cheaper..
I do most of my own cast repairs & in this case I would be looking for a good used before repairing..
If you just can�t find one then you will need to talk repair (should be able to find one though as they are nothing special)..
Maybe someone will see this & make you an offer to sell you one..
Clooney
Jason Z in MO
01-22-2005 19:00:50
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to Clooney , 01-22-2005 18:44:13
Clooney,
Thanks for the quick response. I will start looking for a replacement. This will give me a good reason to make the trip to the Waterloo swapmeet in Feb!
Since I wrote this post I started searching for the lower bushing. The part number is invalid on JDparts. My old one is usable but the repair would require removal which will probably distroy it.
Thanks again!
Clooney
01-22-2005 19:31:11
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to Jason Z in MO, 01-22-2005 19:00:50
960, you should be able to put it in either the white (gen) wire or brown (ret) wire {the brown wire from the generator�s (A2) post at the regulator}.. That is the 24 volt loop & should show charge only.. White (gen) wire would be easier�
You could also install it in either the blue or brown wire at the starter solenoid & that will show a 24 volt charge & � of the 12 volt dis-charge (I think)..
As far as polarity,, just install it & if it reads backwards just swap the wires post to post�
Clooney
wrong spot (sorry)
01-22-2005 19:33:37
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to Clooney , 01-22-2005 19:31:11
Something wrong here as I didn't put it in the wrong place twice..
Duane Larson
01-22-2005 21:06:14
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to wrong spot (sorry), 01-22-2005 19:33:37
Clooney,
I had the same problem a couple days ago - I would have swore I put my response under another question, so ended up responding 3 times before I realized what was going on. I agree there is something odd here.
Clooney
01-23-2005 04:39:53
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to Duane Larson, 01-22-2005 21:06:14
Duane, I was pretty sure I put it in the correct place the first time but it was late at night (for me anyway) so who knows... On the second one showing up there, that I can�t explain as I was more careful that time..
You�re right,, there is something odd here.. I won�t tell you what my wife said about that..
Clooney
Walt in Jaxn Tn.
01-24-2005 13:50:07
 Re: 39/40 B Steering Pedestal Crack - how to repai in reply to Clooney , 01-23-2005 04:39:53
Check out ad #91690 in photo ads --Walt--
