JD 40 Trouble
sw?
01-22-2005 16:17:23
I'm confused about some things with my 1952 JD40. Have milkey oil (slight), 1 plug fouled, hard to crank, sometimes get white smoke out on startup. Seem to be getting some water in the gas, slight frost film at manifold to carbureutor flange this morning after startup. Think it's the head, or could it be leaking in through the manifold and down into the crankcase. Any troubleshooting help on zeroing in on the problem would be appreciated.
CPeter
01-22-2005 17:23:16
 Re: JD 40 Trouble in reply to sw?, 01-22-2005 16:17:23
Is this tractor new to you? If so, start with an oil change and several cans of dry gas, just as Clooney said. The manifold condensation is common on the 40s until it gets warmed up (you may have to cover the grill this time of year). There is no thermostat or water pump on the 40s. They use thermosyphon circulation and in the winter run COLD. They never really heat up unless you work them really hard. I made a cover for the grill that completely covers it and now I can get the temp up. These tractors really like to be HOT. Anything short of boiling is OK. A rebuild on the starter will help - new brushes and bushings will make a big difference. Use the biggest battery cables can get. NOT 12 VOLT ones that you get at the auto parts stores. You may want to run the ground to somewhere very near the starter on the block. The ground on the steering pedestal is noted for having high resistance. 12 Volt conversion is not necessary. I have been starting Dubuques for over 30 years here in New Hampshire and with a good battery, not have any problems. The moisture in the oil could be coming from condensation not being boiled out of the oil because the engine is cold. A hot engine will help with lots of the problems with these engines, from plug fouling to how the run and idle.
CPeter
Clooney
01-22-2005 16:34:48
Sw, you say,,,
Quote:--� Have milkey oil (slight), �
--That is probably from water in it�
�1 plug fouled�
--That is fairly common on the Dubuque tractors (especially if there is water in the engine or air cleaner).. Just install a new plug for now (maybe an H-12 or H-10C)
�hard to crank, sometimes get white smoke out on startup.�
--That could be ice, water in the engine, flooded, etc.. Could also be a low battery (common)
�Seems to be getting some water in the gas,�
--If from the fuel tank it is probably from condensation so try keeping the tank full & use a few cans of dry gas in the fuel.. If from the carb area suspect water in the air cleaner lower cup)..
�slight frost film at manifold to carbureutor flange this morning after startup.�
--That is normal at certain ambient temperatures & humidity conditions.. (nothing to worry about there)
�Think it's the head, or could it be leaking in through the manifold and down into the crankcase.�
--It could be many things.. Make sure the air cleaner cup isn�t full of water (common if stored outside).. If no water there you could have anything from a head gasket, to cracked cyl head, to just moisture from sitting in the cold.
�Any troubleshooting help on zeroing in on the problem would be appreciated.�
--Is it losing any water from the radiator? If so then possibly suspect a head gasket or cyl head problem.. If the radiator is staying up suspect an air cleaner full of water or other water entry like through the exhaust pipe or condensation.. Basically you have to try & look in different places until you find your problem..
Clooney
Lavoy
01-22-2005 19:12:41
 Re: JD 40 Trouble in reply to Clooney , 01-22-2005 16:34:48
Peter touched on it, Clooney might be able to corroborate/correct my figures, but as far as I know it takes a continuous "oil" temp of 140 degrees for 30 minutes to remove moisture from oil. A 40 in cold weather will not warm up no matter how hard you work it. I pushed snow with an MC (same cooling system) for a hour, all it would go and them some. When I stopped, I could hold my hand anywhere on the block and it was cool. Put a set of shutters on it, and close them while working, and it will warm up nicely. In hard pushing, can even open them up slightly.
Just putting a 40 crawler back together right now, and it is getting shutters as well.
Lavoy
Clooney
01-22-2005 19:38:07
 Re: JD 40 Trouble in reply to Lavoy, 01-22-2005 19:12:41
Lavoy, I doubt even 140� is enough heat in the oil.. & even then water temp is usually much higher than the oil..
Quote:--"When I stopped, I could hold my hand anywhere on the block and it was cool"
--That's normal as there isn't any water in the lower block.. Is also why the oil runs so cold..
Clooney
Lavoy
01-23-2005 07:04:22
 Re: JD 40 Trouble in reply to Clooney , 01-22-2005 19:38:07
Clooney,
Even up by the carb it was cool, and lower hose was ice cold. Water in radiator was cool enough to stick my finger in and not get burnt.
I read the 140 deg figure someplace, but can"t remember where.
Lavoy
CPeter
01-22-2005 20:08:26
I also have a 420U with a loader on it. I had many more problems with it until I put a 195� thermostat in it. Now it heats up quickly, runs better, doesn't foul the plugs and starts much easier. On my old 40C that I had for 30 years up until this summer, it was always a problem getting it to warm up. On the new on, the grill blanket helps, but the shutters would be a better answer. They are about $300.00 as I remember pricing them this fall. A good investment for winter use machine.
CPeter
CPeter
