Attn: Coolney - Oil Problem
New to Green
01-22-2005 15:18:37
Purchased a 1952 John Deere B, living in Wisconsin, temperature is cold. Pull started the tractor, tough to get going in the cold. Tractor started but couldn't get the tractor up to high rpm's. Changed oil and found water in the oil, the water was froze. Do you think I did any damage because of the frozen water in the oil, like the oil pump coupling or anything else you can think of.
Thanks for your help. You seem to be knowledge based on your answers to questions.
New to Green - Wisconsin
Clooney
01-22-2005 16:19:45
 Re: Attn: Coolney - Oil Problem in reply to New to Green, 01-22-2005 15:18:37
New to Green, as long as you now show oil pressure with it running it probably wasn�t frozen that hard.. Very seldom does that oil pump coupling survive a cold start if there is ice around the oil pump gears. (MAKE SURE IT HAS OIL PRESSURE)..
As far as other water damage� Depends on how long the water has been in there.. I would worry more about internal rust than ice damage.. The water vapor can condense in the rocker cover & governor & rust those up if it sits in there for a long time..
Run that engine until very hot (block the radiator),, then drop it again & let it settle in a clear jug or many quart jars & see if any water settles to the bottom of the oil (probably will as that water is hard to get out in cold weather)..
Clooney
old
01-22-2005 15:51:32
I'm not Coolney but, as long as you drained it all and you have good oil preasure you are probably alright. If it where me I would run it for a few hours and change the oil a second time just to make sure you get most of the water out of the system.
