4020 loader hydraulics
Richard55
01-22-2005 13:33:10
Does anyone know where to plumb a joystick control valve into this tractor? Also where do you run the return line?I have heard you can use the port just under the brake pedals that feeds the three point system.Thanks for any help.
Pete/ME
01-23-2005 03:58:49
 Re: 4020 loader hydraulics in reply to Richard55, 01-22-2005 13:33:10
Got a filter cover with threaded port from JD, I think for around $60. Sorry, can't find the number, but a good parts guy should be able to tell you. Rigged up extra remotes to run a backhoe by teeing off as below, and a return to the cover. Hoe was a tad jumpy, but you learn to nurse it. This was on an early 4020D,PS.
Mike M
01-22-2005 13:57:12
I put in a tee right ahead of the brake pedal area in the line going back to the rockshaft. I did not use a restrictor.I had a valve off of an old JD 500 loader tractor and used this.I ran the return back into where the 500 had it down on the bottom left hand side I had to drill and tap a block that I think has other return lines in it I don't know what it is called. I will have to look better as I also think I have that tee fitting part number written down.
Mike M
01-22-2005 13:57:17
Gerald J.
01-22-2005 13:48:28
The elbow just in front of the brake pedals has full system pressure and flow available. We discussed this on another list last week.
You replace that elbow with a T. On the open port of the T you want to run through a flow restriction, like a needle valve because you don't need full 22 gpm for the loader. I forked before the needle valve and did two outlets, one for loader, one for back hoe.
The return goes to the cover of the transmission oil filter. I drilled and tapped, it though JD sells one initially made for the 2640 that comes with an oil return hole that doesn't impact the filter element directly.
Take the elbow with you to JD to find the appropriate T, their parts computer doesn't know how many variations there were and they may suggest the wrong part. And that wrong part was hard to find and an expensive part to eat. When I took the elbow to JD the right part was quite reasonable.
Gerald J.
Bob
01-22-2005 14:00:29
 Re: 4020 loader hydraulics in reply to Gerald J., 01-22-2005 13:48:28
No THAT'S a new one! I've been around umpteen 4020 loader tractors, and NEVER have seen one with the flow to the loader valve restricted!
What would be the advantage to restricting the oil flow???
Gerald J.
01-22-2005 20:34:44
 Re: 4020 loader hydraulics in reply to Bob, 01-22-2005 14:00:29
Probably because I have clubs for hands, not sand papered finger tips (I play double bass) and I need the low flow to keep from tossing the load over my head when lifting. Keeping the flow down IS normal on the 4020. The factory remotes have flow restrictor adjustments in their control valves. Keeping flow down to 6 or 8 gpm keeps from making the 3x8 cylinder move from end to end in less time than normal human reaction time. Feeding 21 GPM to a remote cylinder makes that 8 inch stroke take less than a second. Can you stop it without knocking the end of the cylinder out in that time period? The cylinders on my loader are in pairs but smaller diameter than 3 inch.
And preventing the jerking it had when I had a much larger pump on a previous tractor with this loader meant idling the engine and barely caressing the valve handles. When I don't use it every day, making it clumsy proof by restricting the flow before the valve makes it a whole lot easier for me to use, and cuts down on the holes in the machine shed walls.
Gerald J.
twopop
01-22-2005 15:37:04
i have used a restrictor before,but,only when the loader is jumpy,because one or two of the main pump valves were leaking and the owner did not want to repair the pump.
