Head studs - attn Clooney, WTW or anyone else
jd b puller
01-22-2005 12:14:56
Hey guys, I have a '47 B Powerblock that has been used on the farm for 20 years and pulled for about 10 years. As you might imagine, the cylinders are a little out of round. I want to bore it to 5.125 but am having some problems getting the studs out so they can hold it down while they bore it.
1. Any suggestions how to get them out.
2. Are they reusable, or should they be replaced?
3. Should I coat them with something when I reinstall and should they be torqed into the block?
Thanks to all that respond, Ray
Clooney
01-22-2005 14:19:33
 Re: Head studs - attn Clooney, WTW or anyone else in reply to jd b puller, 01-22-2005 12:14:56
Ray, you ask,,,
Quote: --� 1. Any suggestions how to get them out.�
--Heat the base of the studs to block area then let cool & as it cools spray with penetrating oil (that will wick the penetrant in along the threads). Use double nuts on the studs or a stud puller to turn out.. It might take some finesse & a few heatings & coolings but usually they will come out ..
2. �Are they reusable, or should they be replaced�
--There is no way I would use an old stud once it was removed.. You really don�t know if they were ever over torqued, or stretched, or twisted in removal.. (replace them)
--Yes, use any good sealer or locking compound.. I always use Loc-Tite 271 (red) as it is a sealer also.. Don�t turn them in so tight that it raises the block threads at the stud area.
Clooney
jd b puller
01-22-2005 14:23:01
 Re: Head studs - attn Clooney, WTW or anyone else in reply to Clooney , 01-22-2005 14:19:33
Thanks for all your help. I will hit it with some heat tonite after the kids go to bed (that way they can"t hear me cussing).
Ray
Ben So Tex
01-22-2005 16:14:37
 Re: Head studs - attn Clooney, WTW or anyone else in reply to jd b puller, 01-22-2005 14:23:01
To get them twisted off bolts or other thing it alway seem to me like I have to have a bucket of S-O-B handy, Good Luck Ben
jd b puller
01-22-2005 19:04:41
 Re: Head studs - attn Clooney, WTW or anyone else in reply to Ben So Tex, 01-22-2005 16:14:37
Believe it or not they all came out!!! I sprayed each one with PB Blaster before I started. All of them but the long one came out with high but not rediculous effort. The last one I hit it with some heat and then whacked it with a hammer and muscled it out.
Thanks to all!
Mike M
01-23-2005 06:03:18
 Re: Head studs - attn Clooney, WTW or anyone else in reply to jd b puller, 01-22-2005 19:04:41
Heat to a power block,I hope you didn't get it hot enough to hurt the o-rings that seal the sleeves.
Clooney
01-22-2005 19:11:09
jd b puller, now what are you going to do with those evil words you saved up for this job?
Clooney
jd b puller
01-22-2005 19:50:57
 Re: Head studs - attn Clooney, WTW or anyone else in reply to Clooney , 01-22-2005 19:11:09
Probably save them for when i put my stroked crank in... I may need to find a few more simple jobs to do so that I can build up a reserve...
jd b puller
01-22-2005 19:50:49
Mike M
01-22-2005 14:02:42
Get someone that has done those power blocks before and has big enough equipment to bore them with the studs in.This also applies to regular blocks as well. I think those power blocks are sleeved and sealed with an o-ring now may be a good time to reseal it so you don't have a future o-ring leak. Try checking with Hinrich's Repair for pistons,sleeves and advice.
Earl S.
01-22-2005 12:26:18
JD"B", Make sure the shop knows it has to be bored from the back.If he sets up on parallel bars you won't have to remove but a few.Earl
