Scott, if Im removing nuts off of studs, Im not afraid to turn the nuts while hot, but if the studs are hot they become soft, of course, and can twist off. They are bad enough to do it when not soft, let alone when they are. The heatign and cooling expansion and contraction as you mentioned can still help to break away some rust and siezing so give her a try. Ive found its best to use gradual shock n vibration such as hammering the end of a wrench verus a dead pull with a cheater bar. Once they start to move proceed slowlyyyyy yy milking them in and out in and out for removal. If you can get PB Blaster or Kroil or Penetrating Oil etc to get down in them it obviously helps. Use good quality 6 pt sockets undersized if necessary via the use of even metric sizes to get a good bite on any nuts and stud removers or nuts jammed together may provide a wrench bite otherwise. If you happen to break any studs and have to drill n tap, grind them flat and even to get a good centered punch start for first a small then gradually larger bits. Ive had some success by first welding a flat washer to any stud remains sticking out a head etc., and then weld a nut to the washer and wrench them out. If you drill, dont go too deep in the event the heads one of those with pushrod tubes right underneath so you dont drill into them. If you can get the manifold raised enough, it may be possible to use a hack saw to cut the studs off near the head. The studs often become so corroded n stuck to the head, even with the top nuts off they dont release their death grip. Time, patience, soakings with penetrants, and eventually heat then slow shock n vibration is likely the answer. Good Luck, Let us know how you fare, God Bless John T [email protected]
