Best JD 4020 starter
Mark-in-Mi
01-21-2005 15:23:14
Hi
What is the best starter I can get for my 68 4020.Where can I get one at A good price.
Tired of slow cranking tractor.(with new batteries)
Mark
Boog
01-24-2005 05:14:08
 Re: Best JD 4020 starter in reply to Mark-in-Mi, 01-21-2005 15:23:14
I agree with the posts syaing your starter is fine. I have a 3020 and use it for short periods at a time and have the same problem of slow cranking starts. I have found that if I hook up the trickle-charger for a couple hours before any day"s first start, it cranks the starter over much faster. So at least for mine, it is not the starter -- it is short running times just not keeping the batteries properly charged with the old generator.
Mark-in-Mi
01-22-2005 11:36:05
Hi
Thanks for the help.I ran out thru the snow were getting today to the barn and looked,yes it does have A drop intake manifold.This 4020 is A power shift and has the pump release lever on the left side of the console.Both power shifts I"ve had did have this but not the straight 8.Was this standard on power shift? A JD dealer once told me that not many power shifts were sold because the cost.They were $500 more and that was alot of money back then.
Mark
jdemaris
01-21-2005 20:04:54
I haven't kept up with the latest, but when I last worked at a Deere dealership (early 90s), we were putting Nippodensos on the problem tractors. They held up better than the Delcos but cost more to fix. A 12 volt Delco will crank over a 4020 fine when the hydraulics aren't putting an overwhelming drag on the engine at cranking. Try installing a three dollar manual pump destroker on the tractor and see if it makes a big difference. If so, it would behoove you to either fix the hydraulics, or destroke the tractor when you start it. Most of the cranking problems on Deere ag. tractors are rooted in close-center hydraulic drag. My neighbor's 4020 started burning up starters after the tractor was five years old (around 1977?). I put a destroker on it for him then, and it's been fine ever since. Starts down to zero and he refuses to install a block heater. As to the alternator - do you have the Motorola? Sometimes installing a smaller pulley on the alternator will make it cut in faster. The larger pulley used originally is intended to extend the life of the alternator (turns less). If you have a one-wire Delco 10 or 12SI, then it's a foregone conclusion that it will cut in late.
Gerald J.
01-21-2005 16:53:50
The one you have is good. Take it to a good local automotive electric shop, have them put on a new solenoid (to get good contacts), new brushes, and new bushings. Then it will spin the engine fine if the charging system is charging the batteries well The original generators don't charge nearly as fast as a modern car or truck, they need half a day per start to catch up.
Gerald J.
Mark-in-Mi
01-21-2005 17:42:54
 Re: Best JD 4020 starter in reply to Gerald J., 01-21-2005 16:53:50
Hi
I should have included 4020 is a diesel converted to 12 volt in early 1980's.Two 12v parallal.Ben rebuilt before,same with alt.
I'me also curiouse why tractor has to run 1300 rpm before charging starts.Starter shop tells me it's because alt is a high ampereage one.Any cures here.
Owned 3 4020's since early 80's,2 power shift 1 straight 8.None started great.
Any good starters out there,where can I buy at good price.Thanks Mark
Tony in Ontario
01-22-2005 06:33:13
 Re: Best JD 4020 starter in reply to Mark-in-Mi, 01-21-2005 17:42:54
Several guys in my area have put a nippendenso on from the new 8000 series tractors it will fit a 3020 as well as a 4020 without any modifications, and cranks a lot faster than one off of the 30 series.
Gerald J.
01-21-2005 17:57:52
I've read good words about the Nippondenso starter for diesels. My 4020 is gas. With new bushings, solenoid, and brushes, the factory starter (about the right size for a 200 cubic inch car engine) does fine.
The one wire alternator has to self excite before it will charge and that takes 1400 to 2000 alternator shaft RPM in my experience with Delco. When I put a 10SI on my gas 4020, I changed the alternator pulley to the smallest one I could buy and that makes it charge great at all engine speeds once it gets that initial goose to start the charging. The local automotive electric shop had various diameters of pulleys in their catalog for the wide JD belt.
One can change the wiring to a two wire connection where a wire with diode is connected to the "ignition" switch to supply excitation from the battery when that switch is on. The diode is needed on the gas tractor to keep power from feeding back to the ignition circuit from the alternator with the switch off and keeping the engine running. An alternative for the diesel could be a relay run by the oil pressure switch so it supplied 12 volts to that second terminal on the 10SI when the oil pressure was good. Essentially the same as the Murphy switch on a stationary power unit, but probably opposite action. Power the alternator when the engine has pressure, when the oil pressure quits, remove the alternator power. Otherwise connect that second terminal to the same place in the dash that supplies power to the generator light. I've not yet put in the second wire so I do have to goose it to get the charging started then it works super and catches up with even hard starts in a few minutes unlike the old generator that took hours.
Gerald J.
