Hub bolts
Buzz
01-20-2005 19:33:33
I've got a '36 A with cut off rims. I'm wondering how tight to tighten the six hub lock bolts. They're big enough to tighten as they say, "tighter than a misquito's butt stretched over a rainbow", but certainly don't want to crack those hubs. Do need a tight fit though.
ChuckW
01-21-2005 09:19:01
 Re: Hub bolts in reply to Buzz, 01-20-2005 19:33:33
I think the tightening problem came about by trying to tighten hubs on a lubricated spline. The best thing is to dry, take a torch burn off the oil before tightning. If you tighten on lubrication you probably can never get them tight enough to prevent walking. Also one can use parafem(spelling ?) paper to under the collar to allow easy removal of the collar. Just trim off the excess. I feel even pressure probably in the 90-100 lbs torque range should be sufficent to hold. Most of those were designed for the farmer to move with basic wrenches.
easydoesit
01-21-2005 08:11:19
Buzz, I've seen alot of greif over tightening them too much..but I almost lost a steel wheel off of my 4 Bolt B at a recent tractor show. Pretty embaressing and dangerous. Other may have their proceedure but I now jack up the axel and kick the bottom inside of the wheel to see if I can move it. I tightened that 4 Bolt Steel. Easy
JPatton
01-20-2005 20:25:50
Buzz - Careful with those hubs. My experience is that more of those hubs have been broken by over-tight bolts than by loose ones. I have a crack on one of my hubs at one of the bolts. That bolt only gets a slight pull with the wrench now because I don't want to see that crack get any bigger. J
