I did it ugly
farmerboybill
01-20-2005 17:09:50
I finally got the busted bolts out of the head on my 60. Drilling them out to 3/8 and using a punch and chisel to "extract" them did the trick. Man, was it an ugly, screwed up mess. Hopefully, the antisieze will make this less of a chore when I get around to restoring her properly in a couple years. With luck, tomorrow will be the day she fires over for the first time in awhile.
Thanks for all the help so far.
farmerboybill
01-21-2005 05:20:43
 Re: I did it ugly in reply to farmerboybill, 01-20-2005 17:09:50
I think I'll stick with good old grade 5 bolts and 1600 degree antisieze.
ChuckW
01-21-2005 04:36:27
Didn't you use the vise grips? Definitely do not use stainless steel bolts. The key is to have the bolts evenly tightened. There is no listed torque value. I tighten firmly, run tractor and retighted. Tighten from the inside out. Sounds like your drilled out holes may not have the same torque quality, so be careful...I'd use some never seize on threads.
Ben So Tex
01-21-2005 04:23:07
I used stainless steel bolts and after I ran the tractor for a couple of hours, I try to remove them ,the tread weld themself together and then I had some real fun to remove them.I will not use stainless bolts again,,,My two $ Good Luck Ben
Hayman
01-20-2005 22:22:39
Sounds like great progress.
Ivan
01-20-2005 18:28:49
Maybe you could use stainless steel bolts so they come out next time?
GPWT
01-21-2005 09:23:24
 Re: I did it ugly in reply to Ivan, 01-20-2005 18:28:49
Austenitic stainless steel (304, 316, etc) is great for resisting corrosion, but it can gall very badly and seize up. I wouldn't recommend it for this type of application. Also, the strength isn't high enough.
nc jd guy
01-20-2005 20:04:21
Regarding stainless bolts - don't those galvanically weld themselves in place?
Ivan
01-21-2005 19:28:36
 Re: I did it ugly in reply to nc jd guy, 01-20-2005 20:04:21
Do they weld in place just in aheated plce like the manifold or do they do that wherever they are screwed into cast iron?
