60 Crankshaft questions?
LDW
01-20-2005 12:34:24
Hey guys, I've got a 60 that broke its crank, its a late 60, crank casting number is A4902, I cant seem to find a crank very easily, will the crank with casting A4390 fit, anything need to be changed? Any info is greatly appreciated!!!!! Thanks, Larry.
old
01-20-2005 13:09:49
 Re: 60 Crankshaft questions? in reply to LDW, 01-20-2005 12:34:24
I have a crank that is still in what is left of the 60 I have, the tractor was parked and then taken apart because it got water in the engine and then the guy lost a bunch of parts so its only parts now. drop me an e-mail if intrested I think its a 55 by the way
Mike Aylward
01-20-2005 13:00:15
Larry, either casting number will work. The earlier number subs up to the later number you have now which is the same number as the LP tractors took. The later part number is an alloy crank but the older number will work just fine. Hope this helps. Mike
LDW
01-20-2005 13:34:38
 Thanks Guys!! in reply to Mike Aylward, 01-20-2005 13:00:15
Thanks for the responses, I really appreciate it! Hopefully I can return the favor someday! Larry
