520-730 Load Control Shaft Bushing Specs
Tyler-MO
01-20-2005 12:14:32
Does anyone have the specs for the load control bushings (AF3099R) and the load control shaft (F2899R). The bushings are not available from JD and are not showing to be instock anywhere (except greg stephen...and he doesn"t have his set right now). I need specs to try and have a set made (bushings) or try and find an original NOS set. Please let me know if you can help.
Tyler in MO
Mike M
01-20-2005 19:08:23
 Re: 520-730 Load Control Shaft Bushing Specs in reply to Tyler-MO, 01-20-2005 12:14:32
I don't know if the service manual for those hyd. units lists those specs. or not. Do you have a copy ? If you could find some from JD they may be too sloppy as it seems most of their presized bushings are too loose.I'm thinking they do this so they don't get in trouble from when someone beats them up when installing.If you have some made your machineist should be able to give you good advice on fit.
