Inner Screen for Kohler 181S
BenPatrick
01-20-2005 12:04:04
I'm in the process of redoing my Kohler 181S and noticed 4 little 1/4-20 screw holes around the center on the flywheel. I did a bit of research and there is a small inner screen that goes under the air housing of the flywheel.
Found pictures and a ton ton of Kohler engine specs and pics at>Link
Does>Link anyone know if this inner screen is suppossed to be on a '72 Deere 110? or is it for a different 181 implementation?
Bob
01-20-2005 23:44:42
 Re: Inner Screen for Kohler 181S in reply to BenPatrick, 01-20-2005 12:04:04
1972 would make it in the serial range of 250,000 to 260,000.
Checking on JDPARTS for a 110 in that serial range, 250,001 and up, NO inner screen is shown. Email me if you'd like a copy of the parts breakdown.
BenPatrick
01-21-2005 06:46:28
 Re: Inner Screen for Kohler 181S in reply to Bob, 01-20-2005 23:44:42
You are right that JDParts doesn't show it, it would be more of a Kohler part as JDParts.com is missing a few things regarding the Kohlers that they have. Tractor is a T0643 registered on weekendfreedommachines. I would mine having the inner screen to keep the airflow cleaner, but also don't want to go 'non factory'.
