Tyler, there are many way to tighten those pivot points & I have tried most over the years.. One option is to drill both the yoke & rod to next oversize.. That is usually 9/16� pins.. Those pins will work but look mighty large & the holes need to be drilled quite large.. Another way is to weld the holes up, then drill back to standard size�.. That looks good but is a lot of work.. Still another way is drill the holes to the next up metric size & make new pins from metric bolts (you can make nice looking pins from bolts if you chuck the bolt in your drill & hold it to your grinder while rolling the drill to shape the bolt head into a pin head. (those look good & function good).. You could also drill the yoke & rod & press in brass bushings then use standard pins but that is a lot of work & the bushings tend to come out when they wear (will work though) .. OK, now on what I personally do.. I just drill the holes to whatever it takes to make the holes round again (not always the same size),,, then use my lathe to custom make new pins that fit those holes.. Those look like production but fit the drilled holes tightly.. They also look like production as I make the pin heads production size.. Lot of options� Clooney
