H backfiring through carb
Scott in SC
02-14-2004 07:36:17
Have a 42 H that has just had te engine rebuilt.Was running fine, and all of a sudden quit. Will not restart.I'm getting spark, compression, and fuel. The only time it fires at all is when I spray starting fluid to try and start it. All it does then is backfire through the carb.I have checked the spark timing, and it is firing when it should.What do you guys think the problem is?
JDVan
02-14-2004 19:34:51
 Re: H backfiring through carb in reply to Scott in SC, 02-14-2004 07:36:17
I suspect you have a valve sticking. Or a problem in the Rocker arm area.
Scott in SC
02-14-2004 11:00:54
More problems---With both plugs out, and spinning flywheel by hand, there is a "stiff" spot.Shouldn't the flywheel spin freely all the way around with the plugs out??
