JD 'A' Clutch
Dixieland
01-20-2005 04:25:17
I have a 1946 JD 'A' tractor that the clutch won't engage. It won't snap in. If I push forward real hard it won't move the tractor but a little bit. It looks like a bugger to repair before I know what I am getting into. Any help would be appreciated.
Clooney
01-20-2005 14:15:45
 Re: JD 'A' Clutch in reply to Dixieland, 01-20-2005 04:25:17
Dixieland, as Eric said,, start with an adjustment..
If it still won�t snap in you either have broken clutch disks or operating parts or wear on the internal clutch parts..
To find an internal problem you will probably have to disassemble it & inspect the parts..
____On the clutch operation & snap in____
**Those 2-cylinder Deere clutch�s are an over-center type clutch.. What that basically means is 3 little links with a partial ball on each end (toggles) are socketed on one end in the seats of the pivots.. The other end is seated in pockets in the sliding operating sleeve..
**Starting at the clutch hand lever (clutch disengaged)�
When you move the hand lever forward it pulls the operating rod running along the top of the 1st reduction housing to the rear,, that in turn rotates the clutch fork shaft,, that shaft is hooked to the clutch fork,, when the clutch fork moves it slides the operating sleeve towards the clutch pulley,, as that operating sleeve moves outward towards the pulley it stands those 3 �toggles� up,, as they stand up they effectively get longer,, as they effectively get longer they push on the sockets in the �L� shaped pivots,, those pivots (L shaped levers) then change the direction of the force into a pulling force on the 3 clutch adjusting bolts,, when those 3 adjusting bolts are pulled they pull on the clutch outer adjusting disk (that�s the one just below the adjusting nuts),, when that adjusting disk is pulled in towards the pulley it exerts pressure on all the clutch driving & driven disks,, that locks the clutch pulley solid to the engine crankshaft & allows it to drive the transmission reduction gear & input shaft..
That snap you feel (or used to feel) is those 3 toggles going over center as they just slightly pass their highest lift point,, the end of the snap is the operating sleeve snapping out against the clutch pulley & stopping there.. Those toggles snapping over center is what holds the clutch engaged..
When you pull the hand lever back everything reverses from the above & those 3 toggles snap back over center therefore decreasing their effective length & taking the pressure off the pivots & outer clutch adjusting disk..
__Here are things to check if the snap is soft or doesn�t stay snapped in..__
-You will probably find wear on/in the operating sleeve drive pin holes & also find the pin holes worn in the pivots & pulley hub bosses..
-The "T" ends of the adjusting bolts also wear causing a funny feel to the lock in.
-Another place to look for is that the clutch driver isn't worn on the crank splines & moved in too far.
-Probably the place to start is at the driver to crank splines if that area is loose you will have to address that before anything else will help.
-Then look at the operating sleeve drive pin & pin hole [if the sleeve can rotate very far it won't stand the toggles up & over center correctly].
-I'm sure you will also find wear on the pivot pin holes in both the pivots & pulley bosses. You can drill them out & install oversized pins but BE CAREFUL & try your darndest to get those pins back on their original centers & not just in the center of the worn holes [they usually only wear in one direction from their production location]..That is important so the toggle centers remain in the production location].
**If the clutch works ok but just feels funny Deere at one time offered some conical washers to go under the 3 clutch adjusting nuts for the 620-630.. The part number is [AR 21803R].. Those conical washers really help the clutch snap in feel & are (were) quite cheap & definitely worth a try..
@@There was also a service repair for worn clutch systems & that involved grinding about .020�-.030� from the outboard edge of the operating sleeve,, that allowed the operating sleeve to move out farther.. (do that as a last resort after checking all the parts per above)
Any question on the above just post back & ask�..
Clooney
Dixieland
01-20-2005 16:55:39
 Re: JD 'A' Clutch in reply to Clooney , 01-20-2005 14:15:45
Gosh!!! That sounds like what I thought (where to start?). Thanks. I will give these suggestions a try and see if I am smart enough to figure all that out.
Eric E
01-20-2005 07:10:30
did you try to ajust it ???
Dixieland
01-20-2005 07:41:15
 Re: JD 'A' Clutch in reply to Eric E, 01-20-2005 07:10:30
Not yet. I am not sure where to begin.
