1520 specs
deenw
01-19-2005 19:49:19
hi guys just got the head and rods back for the 1520 gas ..had to resleeve and all so should be almost like new..need torque values for the rod caps and head bolts if anyone could supply..that would be great..thanks in advance..was also told that when putting sleeves in some guys apply silicone to the orings and packing ring...is this a good idea or not..this is my first sleeve job..thanks again
Charlie1520
01-20-2005 05:25:43
 Re: 1520 specs in reply to deenw, 01-19-2005 19:49:19
Hi,
I had just replaced the sleaves on my 1520 last fall. I believe that the tech manual recommended using liquid dish soap on the O-rings. The manual also recommended replacing the pistons and rings when changing the sleaves. (I cheated and kept my pistons which looked good.)
I don"t have the torque specs with me now. If you don"t get another reponse before then I can post them here this evening. Hope this helps.
deenw
01-22-2005 07:41:17
 Re: 1520 specs in reply to Charlie1520, 01-20-2005 05:25:43
thanks for your info
