Matt, no that doesnt sound right, so I have to ask more questions and have you run a few checks. Sounds like were not quite home yet. 1) Okay, when you hooked the battery up the ammeter shows - 8, where was it at when the batterys NOT hooked up????? ? If shes near zero unhooked, but swings to - 8 when shes conected (engine not running) it sounds like you have a short somewhere. (See below) 2) If she swings from zero to - 8 when you connect the battery,,,,, , but then when you start her she swings to the positive closer to zero, it sounds like she may actually be charging some, but your short is drawing 8 amps (plus ignition is then taking 4 amps) and she just cant quite keep up. However, that 12 volt generator (depending on its condition and the VR) sure ought to supply at least 10 to 15 amps into a 6 volt system. Maybe 8 to 12 amps is all shes putting out. 3) Okay heres what I want you to try, when shes running at a good RPM and the ammeter is hoverign near zero but up from that - 8, hook a wire up from the Gens Field post to its case ground and see what the ammeter does then??? If she charges more over in the + direction, that VR isnt quite doing its job. If it makes no difference, leave the Field grounded then connect the VR's BAT and ARM (or GEN) terminal together temporarily and see what the ammeter does then, if she charges a lot more and actually gets into the + charging on the ammeter, I suspect a problem in the VR. 4) NOW, if grounding the Gens Field nor hooking the BAT to ARM on the VR makes much difference BUT SHE STILL GOES FROM - 8 TO NEAR ZERO WHEN RUNNING, I suspect you have a short PLUS that Gen isnt putting out all it should. 5) Lets try that Motor Test again: Remove and protect the Gens wires,,,,, remove the belt,,,,, hook the hot wire down from the ammeter that ran to the VR's BAT terminal to the Gens ARM post and see if she spins????? ??? If she does and well, the Gens Armature n brushes are decent at least. Next while running, ground the Gens Field terminal n see if she slows down some???? If so the Field winding is likely okay. Usually if she passes BOTH thoses tests, she ought to charge BUT STILL YOU MAY HAVE A SHORT THATS SUCKIGN 8 AMPS OUT OF THE BATTERY and even if the Gen is basically good, worn brushes or a weak VR may not allow her to charge at say a 10 to 15 or 20 amp range. Still, with the Gens Fiedl grounded and the VR BAT and ARM tied, the VR is out of the equation so if shes still a weak charger, its a GEN and NOT a VR problem. 6) OTHER CHARGING CHECKS: If you have a voltmeter on the battery with engine not running, it ought to read near 6.3 volts,,,,, ,then runnign at RPM if the Gen is working good, it ought to rise to the 6.8 to 7 range dependign on the Gen and Battery condition. However, if you have an 8 amp short discharge, she wont raise much if any. 7) Now lets look for that 8 amp draw short. THIS ALL ASSUMES THE AMMETER IS WORKING AND NOT STUCK. If shes near 0 with no battery hooked up then swings to - 8 when its hooked but goes back up to near zero when running, it sounds like it may be working to some extent. 8) When you hook n unhook the hot ungrounded battery cable with ignition and all else off, can you see any lil sparks????? ? If so, theres a short. If so, unhook the hot battery cable,,,,, place a voltmeter on the battery post and the other end to the disconnected battery cable,,,,, if she reads voltage that means theres a path to ground somewhere, and the higher the voltage the worse (less resistance) the short. If so, start isolating lil circuit feed wires one at a time and attaching the meter to them (other end on battery) to see which wire/circuit has the short. Typical places a wire may be shorted or a device is bad and leaking to ground are,,,,, the ignition switch,,,,,the VR (its BAT terminal),,,,, ,maybe the starter,,,,, ,,ignition wiring down to that Wico,,,,, ,,,,, wires to any lights or light switches. NOTE dependign on the test lamp (if you use it versus a voltmeter), a test lamp may not glow even if there is a short if its a failry high resistance minor short !!!!! !!! since its not drawign enough current. Thats enough for now, SUMMARY: See what the ammeter does with no battery, battery hooked up, then with engine runnign at RPM,, Then do the Gen and VR checks I posted above,,use a voltmeter to see if the battery voltage rises when running,,,,, ,,then look for shorts,,, then post abck your findings and any question n I will try n help more if needed. Let us know, Good Luck n God Bless John T
