4030 starting problems
jamie from onta
01-19-2005 16:09:20
I have a John Deere 4030 tractor that will not start. It has started all winter (plugged in for a couple of hours) but just got notional lately. I got the starter rebuilt this summer and purchased 2 new 6 volt batteries and connecting cable the year before. We tried boosting it and I"m wondering if we blew a fuse or something. I tested the batteries and they both seem fine at 6 volts but I don"t get any panel lights or any noise from the starter when I turn the key. Other than wait for warmer weather, what else can I do? Where are the fuses located?
WTW
01-20-2005 08:34:10
 Re: 4030 starting problems in reply to jamie from ontario, 01-19-2005 16:09:20
jamie, Being you have no panel lights, that tells me that you may not be getting power to the key switch or key switch has a circuitry problem. Key switch supplies power to dash lights and energizes the starter relay. The key switch has power supplied to it from one circuit breaker. The flow of power to the key switch from battery is as follows: Battery power from left battery post, though battery cable to starter solenoid, heavy red wire from battery cable connection on starter solenoid runs up to starter relay connection supplying relay with power, relay located on firewall under back edge of hood. From same connection on relay a heavy red or sometimes black wire comes from this connection and goes through fire wall to connect to a buss bar supplying left row of circuit breakers with power. Top circuit breaker on left side row supplies power to the key switch by way of a red wire. Check for power on both sides of the top breaker and at the actual wire ends that connect to it as this is an area that poor connection do commonly exist on these tractors. All breakers on the left side are hot all the time when tractor is setting and should have power on both sides of breaker terminal studs, only top breaker will affect key switch, other two supply light switch. If all checks are good go to your key switch and check to see if you have power down to it. If power is present at switch continue to test for power while holding the key in the start position as you may learn circuit will fail with load is applied to it. If power drops with load applied, back up on circuit path until you learn where the voltage drop occurred. From key switch power is supplied to the dash lights and to the neutral start switch before it goes back to starter relay to energize it. You most likely will find your problem before or at key switch being you have two separate circuits failing leaving the key switch. The two separate circuits failing are your dash light circuit and the starting circuit. Check to see if your fender lights will come on, if they do power to breakers is fine, problem is from top breaker to key switch. If the fender lights do not work problem is before or at breakers. Good Luck, DW
twopop
01-19-2005 16:57:40
above the floor board,left side,there is a 5/16s bolt that holds the dash cover.remove the dash cover.the circuit breakers and the power relay are located there.if when you turn on the key,you dont hear a click,the relay may be bad.under the hood on the firewall(bulkhead) there is a start solenoid,which may be bad.on the right side of the trans,there is a neutral switch,if it is not connected of does not make contact,she wont start.
flash20
01-19-2005 16:53:11
On a 4430 the fuses are under the metal sheilds infront of the steering wheel. They are atomatic resetting. The key turns on a relay that the fuses are connected to. It should make a click sound when turned on. It may have gone bad.
